Stop Leak additive - Triumph Forum: Triumph Rat Motorcycle Forums
post #1 of 9 (permalink) Old 01-15-2010, 02:24 PM Thread Starter
Other Motorcycle: Kawasaki 2000
Extra Motorcycle: 76 Sportster
Question Stop Leak additive
Has anybody tried a stop leak additive? I have seen a oil additive made by White Shepherd and one made by Lucas made for engine and gearbox. I have a 79 Bonneville that has very small engine oil leak, but I get a few drips a night from the gear box. I have tightened all bolts. I am looking for a temporary fix for now and will get gaskets and look into it further at a later date.
Thanks
Saltare
Saltare is offline
post #2 of 9 (permalink) Old 01-15-2010, 03:46 PM
Main Motorcycle: 2010 Triumph Tiger 1050
TxTiger's Avatar
Other Motorcycle: 2013 Street Triple R
Extra Motorcycle: 2012 Triumph America
I would definitely NOT use a stop leak additive. Small leaks are normal with these bikes. These additives typically swell seals for better sealing, but not good at all for the long run.
I would live with the minor leaks and change your gaskets when you have the opportunity.
Ron
'71 Tiger, restored and beautiful
2009 DRZ 400 SM, BB Kit, Stage 2 Cams, 39 mm Carb, MRD/SSW Pipe (Currently poising as a Dual Sport)
Tiger 1050, HyperPro Racing Rear, RaceTech Front, Arrow Race, 20546 Tune, Madstad, Airbox Mod, Krista's
TxTiger is offline
post #3 of 9 (permalink) Old 01-15-2010, 07:15 PM
Main Motorcycle: '72 Bonneville
RetroRod's Avatar
Other Motorcycle: Suzuki GSX1400
Ron
I second that! RR
RetroRod is offline
post #4 of 9 (permalink) Old 01-15-2010, 07:18 PM
Main Motorcycle: '68 TR6R
68TR6R's Avatar
Other Motorcycle: 1978 suzuki 125
Trying to fix a "minor leak" on a triumph is like beating a dead horse. Sure, you'll fix the leak, but since you took it apart a new leak will form. It's a black hole, of sorts. You cannot fix a bad oil joint by adding something to the oil!!!
68TR6R is offline
post #5 of 9 (permalink) Old 01-15-2010, 08:30 PM
Main Motorcycle: 1959 Triumph TR6
Other Motorcycle: 2003 HD Road King Police
I'll take a minor leak anyday. My preunit is ,by design, is a leaker! I have made some units, pretty much leak free, but nothing lasts forever!
Red1959 is offline
post #6 of 9 (permalink) Old 01-15-2010, 09:06 PM
Main Motorcycle: Mine
t100rc's Avatar
DO NOT put leak preventing additives in your vintage Triumph ... seriously ... don't do it ...
RC
'70 T100
'56 T110 (in progress)
Crossroads Cycle
t100rc is offline
post #7 of 9 (permalink) Old 01-21-2010, 11:52 AM Thread Starter
Cool Stop Leak
Thanks for your reply's. This group knows much more that I ever will on Triumphs, so I appreciate it.
I would like to play devils advocate on stop leak. These bikes tend to be hobby bikes and not ridden daily. When they sit for long periods, seals and gaskets dry up and that is a bad thing. Also, on a hour ride and the oil heats up, it leaks more.
A stop leak additive expands seals and gaskets, so in that sense it is a good thing. What is the long term downside to these additives or why is it a bad thing?
This time of the year, my work schedule will keep me from seeing daylight let alone working on bikes, (although I always find time for some rides).
I also have old hobby trucks , one in particular with a rear main seal leak, so I am really curious on this stuff.
Thanks
Saltare:
Saltare is offline
post #8 of 9 (permalink) Old 01-21-2010, 12:46 PM
Main Motorcycle: The one between my legs
Snakeoil's Avatar
Other Motorcycle: A few
Extra Motorcycle: Yes
Think about it, Saltare. If the stop leak causes seals to expand, what do you think is happening to the material from which the seal is made. Something is changing it, and not for the better. An old trick that was used years ago to accomplish the same thing was to put some brake fluild in the engine oil. It also attacks (this is the proper term) the seals and causes them to swell. It was a tactic used by less than stand-up car dealers to get leakers to stop long enough to sell to some poor schnook.
This stuff does not care which seals it attacks, either. If you have a perfectly good o-ring, it will expand that too, until it squishes out of place and gets chewed up in the process.
I know they make stop leak products for radiators that have compounds in them that actually plug holes. If they have similar junk in oil stop leak products, that's even worse because that kind of stuff does not care about which holes it plugs.
It's your bike to do with as you wish. Just keep in mind that there is no free lunch, bud. If this stuff was the way to go, it would sell like hotcakes and you would not have to ask if it was good stuff. Everyone would be using it and know it was great stuff. I would suspect all the oil companies would be putting it in their oils as well.
It doesn't, nobody that knows engines does and knows it isn't, and the oil companies don't.
regards,
Rob
Snakeoil is offline
post #9 of 9 (permalink) Old 01-22-2010, 09:21 AM
Main Motorcycle: 71 Triumph T120RV Bonnie
Other Motorcycle: 72 BSA A65L Racer
Extra Motorcycle: 71 BSA A65 T-Bolt Bobber
you have a few choices:
you can live with some minor leaks, it isn't going to hurt anything.
you can put some oddball mystery fluid that will stop the leak but cause bigger problems elsewhere
Or you can attack the problem leakpoints in a manner that will not destroy the engine. these engines can be assembled to not leak, but it usually best to fix these issues during a rebuild when the cases are split.
with a Gearbox Leak, is it leaking from the outer gaskets or the inner seal? from the plunger or drain plug? there is no fix all for any of these. the location of the leak determines the fix.
Bones_BIR is offline
Engine stall-out/Shut-off at stop light/stop sign??? jrelloway Daytona Deliberations 11 04-02-2013 11:35 AM
Velocity Engine Additive Red1959 Classic, Vintage & Veteran 6 08-11-2009 09:06 PM
Stabil marine additive ssevy Hinckley Classic Triples 9 06-10-2009 11:06 PM
"Secret" fuel additive bluesjeans Speed Triple Forum 10 10-16-2006 08:36 AM
Brent's Bonneville additive... WaltZ Air Cooled Twins Talk 15 02-05-2006 10:41 AM
