750 conversion - Triumph Forum: Triumph Rat Motorcycle Forums
post #1 of 19 (permalink) Old 01-06-2010, 03:17 PM Thread Starter
bum
750 conversion
How much power and torque do you think I would gain by going from 650cc to 750cc?
bum is offline
post #2 of 19 (permalink) Old 01-06-2010, 04:02 PM
Legend
Not enough to make it worthwhile unless you are going racing, or your old top end is already tired and/or smoking.
If you have unlimited play money, all bets are off!
GrandPaulZ
Author of "Old Bikes"
Born Again Bikes
My Photo album
GrandPaulZ is online now
post #3 of 19 (permalink) Old 01-06-2010, 06:17 PM
Main Motorcycle: Norton Commando
SirDooby's Avatar
Other Motorcycle: Triumph Thunderbird
Extra Motorcycle: Kawasaki KZ550
750 upgrade
In my opinion the long stroke 750 is the most fun of all the Triumphs to ride and that's what you get when you put a 750 kit on a unit 650. If you match it with good cams, carbs and pipes you'll easily have enough power to get yourself into trouble. If you don't re-balance the thing, however, you may want to push it off into the lake.
Bill
1957 Triumph 6T Thunderbird
1962 Triumph 6T Thunderbird
1974 Norton 850 Commando
1980 Kawasaki KZ550 mule
SirDooby is offline
post #4 of 19 (permalink) Old 01-06-2010, 11:14 PM
Main Motorcycle: 62'DBD34
Other Motorcycle: 1970 Morgo T120
Extra Motorcycle: Classic Sidecar Outfit
I agree with the last comment, the Morgo or Routt 650-750
conversion is really good, use with /7016 + 9990 cams. Not too radical and goes really well.
Nick
NickL is offline
post #5 of 19 (permalink) Old 01-06-2010, 11:33 PM
Main Motorcycle: T120RT
KADUTZ's Avatar
Other Motorcycle: T140V,T140D,T140E,T140J
Well in over 31 years I have never found the vibration on my 70 750 to be objectionable. In fact a good friend of mine weighed the stock 650 pistons and the 750 kit pistons and found no difference.
Anyone who complains about the vibration on a Triumph should maybe get a few tools and check all the nuts and bolts.
jus my pinion
K
KADUTZ is online now
post #6 of 19 (permalink) Old 01-06-2010, 11:43 PM
Main Motorcycle: 70 T120R Bonnie
shrugger's Avatar
Other Motorcycle: 72 Norton Combat
Extra Motorcycle: Royal Enfield Bullet 500
Do your cams there corralate with any of these?
http://www.megacyclecams.com/catalog.../page%2017.pdf
And if not. Who sells them?
"Thanks to denial, I'm immortal" -Phillip J. Fry
shrugger is offline
post #7 of 19 (permalink) Old 01-08-2010, 05:09 AM
Main Motorcycle: 71 Triumph T120RV Bonnie
Other Motorcycle: 72 BSA A65L Racer
Extra Motorcycle: 71 BSA A65 T-Bolt Bobber
My Thoughts (I have an M.A.P. big bore kit on a 71 T120RV)
I used an earlier/lighter flywheel crank and had the rotating assembly dynamically balanced.
at idle on the race stand the bike does not creep. the vibrations are signifiganty reduced. also, ran it during the initial run in without the head steady (per the M.A.P. directions).
Performance is snappier, more initial torque and spins up to RPM quicker and with more punch. it pulls the front end loose through fourth gear.
my A65 BSA's will eventually get the same Dynamic Balance treatment.
Needless to say, I am impressed.
Bones_BIR is offline
post #8 of 19 (permalink) Old 01-08-2010, 08:12 AM
shrugger's Avatar
Do you recall what it was ballanced to? 75% 50% etc.
shrugger is offline
post #9 of 19 (permalink) Old 01-08-2010, 11:07 AM
Legend
I guess I ought to clarify my reply, as it was a simple, direct answer to the sole upgrade from 650 to 750.
Without camshaft upgrade(s), exhaust and carb tuning, the big bore upgrade by itself is quite limited.
The cams "wake it up", but are still hindered by the available flow capacity on both intake and exhaust.
The "full package" isn't as stark as a modern 650 vs 750, but is defnitely a seat-of-the-pants noticeable difference.
GrandPaulZ
Born Again Bikes
My Photo album
post #10 of 19 (permalink) Old 01-08-2010, 01:04 PM Thread Starter
bum
Thanks guys. I'll think it over during my engine tear down this winter.
bum is offline
HID conversion anyone? timwu Daytona Deliberations 7 10-26-2009 02:51 PM
18T Conversion hopz Sprint Forum 22 10-22-2009 01:01 PM
Bar conversion Mesoam Daytona Deliberations 0 07-05-2006 10:13 PM
LSL bar conversion Joe275 Triumph SuperSports 22 10-15-2005 03:55 PM
LSL conversion Joe275 Triumph SuperSports 20 06-15-2005 03:50 AM
