68 T120 Points Lead Wire - Triumph Forum: Triumph Rat Motorcycle Forums
Old 12-25-2009, 01:43 PM   #1 (permalink)
Other Motorcycle: 1968 Bonneville
Extra Motorcycle: 1969 Trophy TR6C
Question 68 T120 Points Lead Wire
I am replacing the points lead wire from points to coils. The little round barrel connections will not fit through the hole behind the points plate. Do I need to remove the plate? Frankennut@aol.com
frankennut is offline   Reply With Quote
Old 12-25-2009, 05:05 PM   #2 (permalink)
Favourite Bike: '67 Triumph Bonneville
Remove the plate and snake one wire through, then the second one. Should go one at a time.
GrandPaulZ
Author of "Old Bikes"
Born Again Bikes
My Photo album
Old 12-25-2009, 05:39 PM   #3 (permalink)
Favourite Bike: 77 Bonneville
OzBloke's Avatar
Mark the plate and side of the well with a fine flet tip pen, so you know where it lines up when you put the plate back in.
You should only have the bullet connectors on the end of the wire to feed through, Don't try to feed through the wires with the double-ended female connectors still on them.
Per Ardua Ad Astra
OzBloke is offline   Reply With Quote
Rogue Red wire sprouting from new wire harness Kev_England Classic, Vintage & Veteran 11 11-16-2009 12:08 PM
Setting the Points - 69 T120 gaillarry Classic, Vintage & Veteran 12 10-26-2009 08:46 PM
3-wire signals onto two wire system? Gearhead_42 Sprint Forum 0 01-25-2009 05:14 PM
T100. Good Points v Bad Points. UK Daveski Twins Technical Talk 13 08-15-2007 06:59 AM
points for 650cc T120? drinkNdrop Classic, Vintage & Veteran 2 07-11-2006 11:33 PM
