Info on hardware and wiring needed - Triumph Forum: Triumph Rat Motorcycle Forums
Old 12-24-2009, 12:37 PM   #1 (permalink)
Favourite Bike: '69 T120R
Can someone help me identifying these parts...
A. Don't know what these 2 "screws" are for...
B. Redoing my wiring, and have no heck of a clue what wires are to go to this...
sangalfie is offline   Reply With Quote
Old 12-24-2009, 01:35 PM   #2 (permalink)
Favourite Bike: '67 Triumph Bonneville
That looks like an axle nut, but it's not an original Triumph part.
The wires from that Tympanium regulator/rectifier go as follows:
Red = battery Positive (+) if you are running the standard positive ground system
Black = battery Negative (-)
Two yellow wires go to the two wires coming from your alternator. The alternator pigtail should be coming out the backside of the primary cover, or more likely way up underneath by the engine sprocket that drives the chain.
GrandPaulZ
Author of "Old Bikes"
Born Again Bikes
My Photo album
Old 12-28-2009, 12:01 AM   #3 (permalink)
Hope everyone enjoyed the holidays, and the extended weekend!!
Some quick electrical questions while we are on this subject...
How do I know if I'm running the standard positive ground system...I am to somewhat believe that the PO switched system to a negative ground system, but how can I confirm this.
Also, (red and black) wires from the rectifier should go to the battery? along w/ the wires from the wiring harness?
Previously I only had one wire going to each +/- (battery) terminal
Hardware needed for sissy bar installation bluesforchallah Twins Talk 8 11-30-2008 10:51 PM
Suggestions on wiring info for 1972 t100r Daytona 500 zimp Classic, Vintage & Veteran 10 04-02-2007 10:38 PM
Engine Guard Hardware Info sought... UJMrider Hinckley Classic Triples 9 03-20-2006 09:51 PM
Light specs and wiring info LiveTheDream Speed Triple Forum 1 06-22-2004 07:39 AM
Key Cylinder Wiring Info? Sprint Forum 2 05-16-2004 04:12 AM
