Tri-Cor Oil Filter - Triumph Forum: Triumph Rat Motorcycle Forums
SportbikeTrackGear
New BonnevilleHonda Powersports SportbikeTrackGearMotorcycle.com
Old 12-22-2009, 01:50 PM   #1 (permalink)
Favourite Bike: 1971 Bonneville Street Tr
Hourglassmike's Avatar
Other Motorcycle: 1968 T100R
Extra Motorcycle: 1981 Sportster the Turd
Tri-Cor Oil Filter
Doe's anyone know what filter element TriCor use's in there RS004 OIF oil filter sump kit?Tried to Email TriCor and that didn't work.
I have went to Napa and a few other local auto parts store and tried to match one up to no avail.It's 2.625 high by 1.660 in diam.
Any Suggestions
Mike
Hourglassmike is offline   Reply With Quote
Old 12-22-2009, 02:42 PM   #2 (permalink)
Favourite Bike: Triumph Bonneville
Other Motorcycle: Triumph Speedtriple
Is this the type you mean?
http://triumphbonneville.com/shopsit...ter%20kit.html
If so, I've no idea if there is a cross reference for a generic modern filter but they should be available from most Vintage Triumph shops.
Webby
Webby is offline   Reply With Quote
Old 12-22-2009, 04:01 PM   #3 (permalink)
TriCor
Yes, that's the filter.
For some reason it look's more like a Fuel filter,for what I don't know.
This is the second time when I changed the oil. I cleaned it with some carb cleaner,I don't think that I can do that anymore.
Thanks.
Old 12-22-2009, 04:30 PM   #4 (permalink)
Favourite Bike: My 1978 Bonneville T140V
MORRISTHECAT's Avatar
HGM,
I had the same problem- not wanting to go to Raber's online every time i needed a replacement filter.
Local Autozone had a better one, from memory, CH9620 FRAM Cartridge type filter- approx. $10.
It's actually a bit larger than what came with the kit and works great.
Cheers and Happy Hol's,
Brien
cura ut valeas
Morris of Main Street
MORRISTHECAT is offline   Reply With Quote
Old 12-22-2009, 04:33 PM   #5 (permalink)
Hi Mike,
Try the following, (I guess you're in the US):
www.bornagainbikes.com (GPZs place)
http://www.baxtercycle.com/
http://www.britishonly.com/
http://www.moorescyclecenter.com/
http://www.klempfsbritishparts.com/
I hope this helps
Webby
Old 12-22-2009, 06:24 PM   #6 (permalink)
Thank's guy's ,I'm on my way to Auto zone right now.
Happy Holidays
Mike.
Old 12-24-2009, 10:18 AM   #7 (permalink)
Favourite Bike: 67 Triumph T120RC
Transgarp's Avatar
Other Motorcycle: 86 Honda XL600RG
I used Trident filter, original part.
My kit is from Tri-Cor
Transgarp is offline   Reply With Quote
Old 12-24-2009, 01:31 PM   #8 (permalink)
Favourite Bike: Rocket 111
Other Motorcycle: Triumph T140V 750
Extra Motorcycle: Triumph Rocket 111
I don't know its exact part number but I can tell you that its identical to the one which BSA used in the oil-in-frame B25SS and B50SS machine..
bonnietiler
bonnietiler is offline   Reply With Quote
Old 12-24-2009, 03:26 PM   #9 (permalink)
Favourite Bike: 1978 T140 -e
Other Motorcycle: 1979 Yamaha SR500
Fram ch6062 looks to be close match.
http://www.calsci.com/motorcycleinfo/FilterXRef.html
chew652 is offline   Reply With Quote
Old 12-24-2009, 06:00 PM   #10 (permalink)
Thank's guy's
I stumbled across the BSA B50 part number last night.
The Fram number looks good as well.
Merry Christmas and Have a safe New Year!
Thank's for your help.
Mike.
Oil, filter and air filter questions for '01 S3 lwolniak Speed Triple Forum 5 04-13-2008 02:40 PM
Is this a K&N or Uni filter Skyblue62 Twins Technical Talk 8 09-01-2007 06:52 PM
TT600 Oil Filter (Triumph OEM VS. K&N Oil Filter) spin Triumph SuperSports 14 06-12-2007 12:49 AM
Which jet kit and filter go best with 904 kit? keef Twins Talk 20 12-25-2005 03:19 AM
Fuel Filter/oil filter/oil type Anchorbend Twins Talk 4 07-24-2005 02:00 AM
