Oil Leak........ - Triumph Forum: Triumph Rat Motorcycle Forums
SportbikeTrackGearHonda PowersportsMotorcycle.comMotorcycle.com Classifieds!
Old 12-21-2009, 01:14 PM   #1 (permalink)
Smile Oil Leak........
Hi all,
On my 1966 TR6R there is some oil collecting on the engine case at the timing hole bolt. it seems to be running down the engine fins. I can't really see the source. Could it be a leaky head gasket or push rod tube seal? Is there something more likely before I start tearing things apart?
Oily in Santa Barbara....
Curtis
1966 Trophy is offline   Reply With Quote
Old 12-21-2009, 03:49 PM   #2 (permalink)
Favourite Bike: 77 Bonneville
OzBloke's Avatar
Most likely the top push rod tube seal. To fix it you'll need to take the head off anyway, so you'll need a top-end gasket kit. Do all the push rod tube seals while you've got the head off.
Per Ardua Ad Astra
OzBloke is offline   Reply With Quote
Leak Baby Leak, More! More! timbo2 Twins Technical Talk 25 06-17-2009 11:05 PM
Oil Leak..........00' RS BlewBayou Sprint Forum 8 08-03-2007 02:00 AM
another oil leak sweatmachine Twins Talk 10 05-23-2006 09:33 AM
Bad oil leak CHGOTHNDER Classic, Vintage & Veteran 21 05-17-2006 10:14 AM
OIL LEAK vanpraag Sprint Forum 11 07-21-2005 08:38 AM
