Originally Posted by mr noisy
I think Ming may be right, - the numbers are not very clear. Logbook says 650cc though - is there any way of telling from the engine?
Steve
Hi,as far as I know if the engine was a 650 ,the number should read something like this;two letters,for the year and month,followed by the serial number,******followed byT120R,or RV,"V" denotes five speed gearbox,these letters and numbers will be the same in the logbook,unless the engine has been changed at some point,if the engine has been miss stamped the format of the number you have would suggest it is a miss stamped 750, T440V,it would be more difficult to "accidently" stamp a T120R with this number,but there are lots of guy's on this forum,who know more about this subject than I do,maybe someone else can throw a little more light on it for you,I hope this helps you,
regards,
Bill.
