Hollow dowel tappet Oil feed - Triumph Forum: Triumph Rat Motorcycle Forums
New BonnevilleSportbikeTrackGearOntario Tourism
Old 12-20-2009, 01:20 PM   #1 (permalink)
I hope this doesn't sound like a dumb question but I am rebuilding the bottom end of my 1974 T140 V and obviously being careful putting it back. However, my parts manual calls for 2 hollow dowel tappet oil feeds 70-.5032 I can see where one is located on the top of the crankcase and obviously slots into the barrels but where is the other one located?
jumbocomic is offline   Reply With Quote
Old 12-21-2009, 03:46 AM   #2 (permalink)
DAGAD's Avatar
No, not a dumb question. There is only one.
Roy.
Old 12-21-2009, 02:54 PM   #3 (permalink)
Thanks Roy
Old 12-03-2010, 11:47 AM   #4 (permalink)
Favourite Bike: 1971 Trophy
Removal of Dowels
To add to this dowel discussion, how do you remove one of these? And can you reuse it or is a new one required? Thanks.
stardust is offline   Reply With Quote
Old 12-03-2010, 12:24 PM   #5 (permalink)
Favourite Bike: '68' T120 Bonneville
Other Motorcycle: 2006 T100 Bonneville
Extra Motorcycle: '79' T140 street tracker
They are pressed in and have an interference fit. They can be carefully removed with a pair of pliers or vise grips. I usually find a drill bit or metal rod that will fit snugly inside to keep them from being crushed. Sometimes they get damaged in removal depending on how much rust and corrosion has locked them in place. Minor scratches can be blended out and reused. Why do you want to take it out?
jimmy bush is offline   Reply With Quote
Ok I figured out it was the starter dowel but now it won't start? sawyer Club Cafe' 8 07-07-2009 10:10 PM
tappet blocks!!!! dirtyharry Classic, Vintage & Veteran 8 04-14-2008 09:23 AM
exhaust tappet oil feed drillway tigercub Classic, Vintage & Veteran 6 02-29-2008 01:10 PM
RSS feed ctrhenry Speed Triple Forum 3 01-29-2007 06:08 PM
Hollow Spindle Crash Bobbins............ KuzzinKenny Tiger Mods & Bolt-Ons (archive) 2 12-03-2005 08:44 PM
