Just went and pulled the plugs out of my '71 Bonnie.
Running a tad rich...
All the books tell me to use a Champion N3 (or equivalent), it has a Boyer, but it is an analogue Boyer, so the N3 should be OK? I ended up with a NGK B8ES which is the correct cross match to a N3.
Pulled the old plugs out and they were NGK BP5ES which cross reference to a Champion N12YC.
The old plugs have possibly an extra half a mm of thread measured by placing the threads against each other in a top to toe position. And as in the pic the old plugs electrode and hookie thing is much more "proud" out of the end of the plug than the N3 Equivalents.
Anyone come up with a possible reason for the P.O. using the different plugs, would there possibly be a mythical performance reason?
I also "gapped" the old plugs with my feeler guages, and they were set at around 30 thou, as opposed to the recommended 25 thou in the manual. The new NGK's are also "factory set" at roughly the same 30 thou gap. I have never had a misfire problem with the old plugs at 30 thou, should I just screw the new plugs in at the same factory setting they came out of the box in, 30 thou?
I am bit worried the above question might have a piece of string answer, or be like an oil thread, (shudder) and have no black and white answer.
Anyone game to answer?
Notes: -
Cross reference page is
here I recommend that page for a bookmark. Just use the search function in your browser to find your plug.
