Clutch replacement question. - Triumph Forum: Triumph Rat Motorcycle Forums
Old 12-20-2009, 06:14 AM   #1 (permalink)
Favourite Bike: 71 Bonnie
dogtired's Avatar
Had the clutch out of my '71 Bonnie yesterday, and was really surprised with the simplicity of the construction. Nice low tech setup.
While I had it out, I came to the conclusion it was stuffed, the fingers on the bonded driving plates had considerable wear where they slot into the duplex chain sprocket/housing. There was similar, but not as pronounced wear in the housing slots. The driven plates, (the plain metal ones), had practically zero wear, and I could still see what looked like very feint regular "swirly" machining marks on the metal.
After inspection I stuck it all back together and set it by the manual. All works as supposed to, and have eliminated the slipping I encountered when on the dyno. Took it out the road and run it up to a bit over 80 mph up a hill a few times under full stress. (Damn I love riding this pig of a bike!)
As of now, the slipping looks like it was mostly from incorrect setup of the pressure nuts/springs from the P.O. and possibly poor setting of the adjuster pin on my part. I will continue to flog around on it untill such time as the clutch starts to give me trouble.
I never inspected the drive and rebound rubbers, (didnt have an impact driver) but will replace them when the bonded driving plates get done.
Now, the question.
Would I be right in assuming that I would only need to replace the 6 bonded driving plates, and most likely the duplex chain sprocket/housing? Or do the plates come as sets, and you need to replace all 12 plates?
Can a storm be officially designated as a tornado without touching down at a trailer park?
Last edited by dogtired; 12-20-2009 at 06:16 AM. Reason: so I can put the really small writing here.
dogtired is online now   Reply With Quote
Old 12-20-2009, 08:16 AM   #2 (permalink)
Favourite Bike: 77 Bonneville
OzBloke's Avatar
Dogtired,
If the driven plates are OK on the fingers, and not overheated (burn marked) or scored, just get them garnet blasted (~$15), and stick em back in. Next time you're in there, check the springs for free length, and replace if short.
Per Ardua Ad Astra
OzBloke is offline   Reply With Quote
Old 12-20-2009, 08:29 AM   #3 (permalink)
dogtired's Avatar
Ozbloke, I didn't have a mic to accurately measure the springs, supposedly if they are a 1/10th of an inch short you replace them, but I did do a quick visual with a couple of straight edges to make sure there was not a short one amongst them, all the same length. I was mainly in there as a bit of a "look see" excercise and got a bit carried away pulling things apart.
There was no heat colouration of the driven plates at all, which I was happy to see.
Mind if I ask what garnet blasting is?
Is it done to just remove any near invisible residue on the plates, or to give the plates "grip" by applying a texture to the metal?
Old 12-20-2009, 08:34 AM   #4 (permalink)
OzBloke's Avatar
Garnet blasting = sand blasting with garnet particles instead of sand. Sand blasting will work just as well, I reckon. Just takes the polish of the surfaces, and gives it a bit more grip without making it so rough it chews out the bonded plates too quickly.
Per Ardua Ad Astra
Old 12-20-2009, 08:49 AM   #5 (permalink)
Favourite Bike: T120V
Caulky's Avatar
I`m in the process of doing mine.
The tangs on the plates were burred, so I cleaned them up with various files. (needle and flat).
If your primary chain is off, (mines soaking in oil) it can be checked by drawing a line 12" long.
This should align with 32 links.
The compression and stretch shouldn`t be more than 1/4".
Ignore the lower 12 1/2" lines, they`re for the main chain, which is knackered.
Apologies for the poor quality, its been used
Caulky is online now   Reply With Quote
Sprag Clutch Replacement cafetbird Maintenance Tips and Tricks for the T3 Classics 23 08-02-2010 02:02 PM
clutch lifter arm replacement question italialaw Daytona Deliberations 8 07-31-2009 01:19 PM
Clutch replacement question mn9130s Twins Technical Talk 2 05-18-2008 09:58 AM
Clutch Replacement Flex Speed Triple Forum 1 11-01-2007 11:10 PM
Replacement Clutch BonnevilleJoe Classic, Vintage & Veteran 3 09-08-2005 02:58 AM
