Oil return - Triumph Forum: Triumph Rat Motorcycle Forums
SportbikeTrackGear
Motorcycle.com Classifieds!Honda Powersports New BonnevilleMotorcycle.comOntario Tourism
Old 12-19-2009, 06:07 PM   #1 (permalink)
Favourite Bike: bonneville
Oil return
How long does it take for the oil return to start dripping oil back into the tank, i've ran the bike only for a few minutes during testing, say +/- 5 minutes and the little hole has yet to produce a drop of oil nor has the oil level seemed to have changed at all.
tkedge1 is offline   Reply With Quote
Old 12-19-2009, 06:14 PM   #2 (permalink)
sorry, 1967 T120 engine...
starts up just fine, but i'm not sure what's up with this oil thing, maybe i'm just being overly nervous and not letting it run long enough.
Old 12-19-2009, 07:11 PM   #3 (permalink)
Favourite Bike: '72 Bonneville
RetroRod's Avatar
Other Motorcycle: Suzuki GSX1400
Yep, you may have good cause to worry on this one. You don't say if its a new startup, but it is always advisable to prime these engines with the kickstarter to be sure.
My '72 pumped to the tank using the kick start in about 15 mins, with oil added to the sump. If you have drained the sump, then you will have a delay as the pump intake passes some oil to be scavenged. 5 mins at idle is about 5000 revolutions, and I would guess a good working pump would have gotten oil back to the tank in this time.
The risk here is having those big ends without oil for any time.
If in doubt, pour a little oil into a rocker cover, then get those plugs out and start kicking!!
Others here with more direct experience, might have some advice on this lag between delivery and scavenge. RR
RetroRod is offline   Reply With Quote
Old 12-20-2009, 05:42 AM   #4 (permalink)
Favourite Bike: Triumph Bonneville
Other Motorcycle: Triumph Speedtriple
5 minutes sounds like a very long time. When I rebuilt my engine the oil was squirting out by the time I opened the oil filler cap.
Prime the engine with about 1/4 pint of oil in the crankcase and then kick it over for a good couple of minutes with the ignition off. Then try starting it and see if you're getting any oil.
I hope this helps
Webby
Webby is offline   Reply With Quote
Old 12-20-2009, 06:23 AM   #5 (permalink)
Favourite Bike: 71 Bonnie
dogtired's Avatar
Wonder if it is worth just slipping the rubber hose off the outlet where it leaves the engine from the scavenger pump and seeing just what volume is coming out of there?
I know this will sound silly, but when you have the rubber hose off, have a quick blow through it to make sure it is not blocked by something stupid like a paper wasps nest in it. I chased a chainsaw round and round for ages once only to eventually find a wasp nest in the exhaust.
I hope for your sake tkedge1 it is something as simple as this.
Can a storm be officially designated as a tornado without touching down at a trailer park?
dogtired is online now   Reply With Quote
Old 12-20-2009, 08:24 AM   #6 (permalink)
Favourite Bike: 1978 Triumph Tiger 750
hobbit's Avatar
Other Motorcycle: XLH883C Sportster
Also check the pipes are the right way round.
Amazing things indicators . . . pity yours don't work.
http://www.aavmcc.com
http://www.shinbukankendo.com
hobbit is offline   Reply With Quote
Old 12-20-2009, 09:02 AM   #7 (permalink)
Favourite Bike: T120V
Caulky's Avatar
Dont start the engine without ensuring the scavenge is working.
(too late?)
Do what others said...kickstarter with plugs out, etc.
If its not working, you`ll have to check the oil-pump.
Caulky is offline   Reply With Quote
Old 12-23-2009, 12:58 AM   #8 (permalink)
thanks everybody, so I removed the plugs and kicked and kicked etc... I got nothing going inside the oil tank, no burping, no bubbles, nothing... and nothing coming back from that little return hole at the top.
i'll be taking it apart soon to check it out.
it's not a new build, but it might as well be, has been sitting for a long time with no oil in it, so i was expecting it to be a bit till oil came out, but really 5 minutes of running is plenty...
Old 12-23-2009, 11:22 AM   #9 (permalink)
Favourite Bike: The one between my legs
Snakeoil's Avatar
Other Motorcycle: '76 Triumph T140V
Extra Motorcycle: '66 Triumph T120R
Not a good idea, Dog. That hose is also the oil feed to the valve train.
regards,
Rob
Snakeoil is offline   Reply With Quote
Old 12-25-2009, 12:13 AM   #10 (permalink)
Favourite Bike: Triumph TR7V
Other Motorcycle: BSA B40 SS90
Extra Motorcycle: Buell M2
Try priming the engine oilways by removing the pressure relief valve, turn engine over until oil is seen coming out the pressure relief valve hole, refit valve and turn engine over until oil is seen getting back to the tank.
394c is offline   Reply With Quote
Revenge not Return? trypcil Biker Hang-Out 16 11-30-2009 11:27 AM
A return to Bridgestone's. trypcil T3 Sport / Touring Forum 9 11-04-2009 06:38 AM
Looking to return to the Bonnie HospiceRN Twins Talk 20 03-30-2008 11:42 PM
Ariel's return? Old Scratcher Biker Hang-Out 19 01-20-2008 07:43 PM
The Trophy's Return Fatbob Trophy 27 08-13-2004 11:59 AM
