Clutch slipping. How-to adjust? - Triumph Forum: Triumph Rat Motorcycle Forums
Motorcycle.com Classifieds!Honda Powersports New BonnevilleMotorcycle.comSportbikeTrackGear
Old 11-21-2009, 02:33 AM   #1 (permalink)
Favourite Bike: '67 T100C Sport Tiger
Other Motorcycle: n/a
Extra Motorcycle: n/a
I recently puchased a '67 T100C. Had some work done on engine and while in the break-in period I have had issue with clutch slipping. It orginally was only in 3rd gear. I messed with the 'adjuster pin nut' for the 'clutch operating rod'. Now the issue seems to only be happening in 2nd gear. Now in 2nd gear it will actually pop out of gear.
Question: Does this sound like an issue resolved with adjustment of adjuster pin nut & clutch rod?? Or am I looking at replacing the 'clutch plates'. I have watched 'lunman' YouTube video on 'setting up the clutch' and looks fairly straight going.
Anybody had similiar issues with bikes clutch? If so, what was you resolution?
RensFunHog is offline   Reply With Quote
Old 11-22-2009, 05:33 PM   #2 (permalink)
Favourite Bike: Triumph Bonneville
Other Motorcycle: Triumph Speedtriple
Hi,
It sounds like a clutch adjustment issue. It's very easy to adjust.
1) FULLY slacken off the cable at the lever.
2) FULLY slacken off the adjuster at the other (gearbox) end of the cable.
3) Slacken off the lock nut on the clutch.
4) Turn the adjuster screw until it just touches the operating rod (you will feel this)
5) Back the screw off 1/4 of a turn.
6) Retighten the locknut
7) Take up any slack in the cable using the adjuster at the gearbox end of the cable.
8) Do the final adjustment at the lever.
And most important watch Plewsy's (lunmad's) video. It's here under the technical tips and tricks section.
I hope this helps
Webby
Webby is offline   Reply With Quote
Slipping Clutch CrazyChris Sprint Forum 0 11-15-2008 07:35 PM
Slipping Clutch? TwistyRD Maintenance & Workshop Talk 1 06-26-2007 04:43 PM
Clutch slipping? uncliggi Classic, Vintage & Veteran 2 07-21-2006 09:45 PM
R3 clutch slipping tommythistommyt The Rocket Science Forum 11 07-03-2006 07:10 PM
clutch slipping greenocktriple Speed Triple Forum 3 06-22-2005 02:58 PM
