T140D Front Brake Routing and attachment - Triumph Forum: Triumph Rat Motorcycle Forums
Ontario TourismMotorcycle.com Classifieds!Motorcycle.comHonda Powersports
Old 11-20-2009, 05:46 PM   #1 (permalink)
Favourite Bike: 2010 KTM Adventure 990 R
Rayzor61's Avatar
Other Motorcycle: 05 Speed triple (4th one)
Extra Motorcycle: Working on it!
Can someone post a picture of the proper (Stock) set-up on the front brake line. Mine is rigged and looks sloppy. I'm most interested in where it attaches to the lower triple clamp. I think the previous owner replaced the inccorrect oil lines and extended them with flexable metal tubing. the resivour (where the brake light switch is located) is zip tied to the mounting bracket. Much thanks!
Buy as many bikes as you can before you die, and try to live!
Rayzor61 is offline   Reply With Quote
Old 11-23-2009, 08:26 AM   #2 (permalink)
Favourite Bike: T140 E
I have an E (79) and can try to take pictures tonight.
I'd guess that the D is the same
I've just put steel hoses on, the top hose goes through the yoke (clamp/tree) and then a solid pipe with in-line switch runs to the bottom yoke. It goes through an eye bolt that also clamps the fork leg, before becoming a hose again.
The hose runs down to the mudguard/fender with a small bracket where the guard is bolted to the leg. It becomes a pipe between the bracket and the caliper.
Sorry for the wordy description!
DAVE M is online now   Reply With Quote
Old 11-25-2009, 10:39 AM   #3 (permalink)
Rayzor61's Avatar
Thanks Dave. I'm kinda ok with the length from the caliper up to the fork flange but after that, I'm lost. A picture of the line where the brake light junction is would be great!
Old 11-25-2009, 12:44 PM   #4 (permalink)
here you are - taken with my phone and one hand so clear enough with luck!
http://s794.photobucket.com/albums/y...view=slideshow
I hope that the D is the same but the pipe goes from top of the yoke to the other side bottom - like half of a swastika and the pressure switch is in the middle
cheers
dave
Old 11-25-2009, 12:56 PM   #5 (permalink)
Favourite Bike: 1995 Daytona 1200
SlowPocono's Avatar
Other Motorcycle: 1979 T140E, '06 Scrambler
Extra Motorcycle: 851 Sprbk, YZF R-1, SV650
I don't know if my 1979 E model is a good enough example, but here's what mine looks like.
I guess RAT.NET is still having issues with picture posting.
T140D Front Brake Routing and attachment-img_1687b.jpg   T140D Front Brake Routing and attachment-img_1688b.jpg   T140D Front Brake Routing and attachment-img_1691b.jpg
SlowPocono is online now   Reply With Quote
Old 12-01-2009, 12:09 AM   #6 (permalink)
Rayzor61's Avatar
Dave, You have no idea how much this helps me. The trouble you went thru to help a buddy triumph nut out is very appreciated. I owe you a beer. Your pictures say 1000 words. I thought it may route through the triple tree yoke because nothing else makes sence to go through that hole. Now my brake line will reach the bars and not dangle around the steering yoke. PERFECT!
Pocono, thanks very much but I couldn't open your pictures, they may be clearer then Daves.......send them directly to biketuner@verizon.net
She's almost done. I send before and after pictures of the restoration....
Old 12-01-2009, 01:25 PM   #7 (permalink)
no probs
Old 12-01-2009, 04:04 PM   #8 (permalink)
Rayzor61's Avatar
Job done! When I bought this bike it was held together with glue and bandaids. Fortunately most of the parts just needed a good cleaning and put back the way they were supposed to go. Everything seems to be working fine now. Thanks for the photos.
Routing of Speedo cable and Front Brake hose? Thunder_ZA Hinckley Classic Triples 3 09-02-2008 03:47 AM
Brake light not working for front brake uber Speed Triple Forum 2 06-24-2008 06:50 AM
front brake / brake light question JACKAL Maintenance & Workshop Talk 2 04-11-2008 06:44 PM
Brake trouble, anybody else rebuilt the front brake Master cylinder uzidzit Twins Technical Talk 3 10-13-2007 01:55 AM
front brake hose routing 05Truxter Club Cafe' 2 04-10-2007 08:17 PM
