Mystery Wire - Triumph Forum: Triumph Rat Motorcycle Forums
Motorcycle.com Classifieds!Motorcycle.comHonda PowersportsNew Bonneville
Old 11-19-2009, 09:55 PM   #1 (permalink)
Mystery Wire
OOPS! In preparation for my Boyer install I mounted 2 new 6 volt coils and I did not mark all of the wires that I pulled off of the old Lucas coils. I've got 2 connectors with 2 light brown wires (probably white in color 43 years ago) each attached that have continuity to the ignition switch but there is a single white mystery wire. It does not go to the headlight bucket. In the picture it is the middle wire. Help please!
Curtis
1966 Trophy is offline   Reply With Quote
Old 11-19-2009, 11:09 PM   #2 (permalink)
Favourite Bike: '67 Triumph Bonneville
Forget the entire original section of ignition wiring harness including the condensers. It will all be deleted with the Boyer unit.
Refer to the Boyer wiring diagram from now on.
...and tape off any unused white and Brown/wht wires.
GrandPaulZ
Author of "Old Bikes"
Born Again Bikes
My Photo album
Old 11-20-2009, 09:44 AM   #3 (permalink)
Smile Mystery Wire
Wow! That sure makes it easy. I'm going to use one of the switched pairs to power the Boyer box. The single wire has no continuity with the pairs. Where do you think it goes to? Should I connect it to the other switched pair or leave well enough alone?
Thanks a lot for all the help that you have given.
Curtis
Old 11-20-2009, 11:32 AM   #4 (permalink)
All you need from your original harness is the switched White wire to power the Boyer box. Everything else that can be disconnected and removed shold be removed. The remaining wires that are disconnected, but part of the main harness, should be taped off.
GrandPaulZ
Born Again Bikes
My Photo album
Rogue Red wire sprouting from new wire harness Kev_England Classic, Vintage & Veteran 11 11-16-2009 12:08 PM
replaced battery and found a 'mystery' wire/plug ryancoleuk Twins Technical Talk 4 05-21-2009 11:39 AM
3-wire signals onto two wire system? Gearhead_42 Sprint Forum 0 01-25-2009 05:14 PM
mystery wire and photos omphoto Twins Technical Talk 5 01-19-2008 02:35 AM
its a mystery to me! doodledog Biker Hang-Out 5 07-10-2007 06:03 PM
