650cc Unit Rebuild Kit? - Triumph Forum: Triumph Rat Motorcycle Forums
Old 11-18-2009, 10:02 PM   #1 (permalink)
Favourite Bike: The one I've yet to build
RidingDonkeys's Avatar
Other Motorcycle: 1967 Bonneville
Extra Motorcycle: 1968 Tiger
Probably a rookie question, but does anybody offer a "rebuild kit" for the 650cc engines?
It seems you can buy a "kit" that included the necessities for any vehicle engine out there, but I can't find one for a 650cc Unit.
Spare parts are never a bad thing and I figure that'll save me the trouble of identifying and ordering all the parts individually.
'67 Triumph Bonneville (Ruby)
'68 Triumph Tiger (Livia)
'73 Honda CB750 Cafe Racer (Sophie)
'11 Ural Gear-Up (Boris)
RidingDonkeys is offline   Reply With Quote
Old 11-18-2009, 11:40 PM   #2 (permalink)
Favourite Bike: 2008 Bonnie
johnny black's Avatar
Other Motorcycle: BSA A65
Man thats crazy talk,I've been rebuilding BSA A65 twins for the last 20 years and never found a part or reference that corresponds with any ''rebuild kit''The Triumph guys are gonna say 'what year',whats the bore size,etc.etc Hope yer wifes patient J.B.
johnny black is offline   Reply With Quote
Old 11-19-2009, 12:59 AM   #3 (permalink)
Favourite Bike: '67 Triumph Bonneville
The parts books list several rebuild kits including gasket kits, rings & pistons, and a few others, however, there is no definitive "rebuild kit" per se, that lists the typical stuff.
Mainly because there are several types of "rebuilds":
-"De-coke" - top end carbon removal / major tune-up
-Valve job
-Ring Job
-Bottom end rebuild
-Total overhaul with good core componets
-Total overhaul after catastrophic failure
On a typical overhaul, I use:
-Complete gasket set with head gasket & o-rings
-5 piece seal kit (even those have to typically be ordered as 5 parts)
-Various fiber & copper washers for drain plugs and OPRV
-Tab washers for clutch center, alternator rotor & kickstart pinion
-Connecting rod shells & bushings
-Pistons, pins & rings
-Valves & guides
-Main bearing pair
-Transmission bearings & bushings (about 8 parts, I think)
-Sludge tube & Allen-slotted trap plug
-Carb kit(s) with new floats, needles & seats
-Clutch fiber plates & springs
-Primary chain & adjuster pressure foot
-Spark plugs
I'm not sure, but probably leaving out a few things...
GrandPaulZ
Author of "Old Bikes"
Born Again Bikes
My Photo album
Old 11-19-2009, 01:03 AM   #4 (permalink)
Favourite Bike: 1972 Triumph TR6R
psasak's Avatar
Other Motorcycle: 1968 BSA A65L Lightning
Extra Motorcycle: 2005 Triumph Bonneville
... not to mention (most likely) front sprocket and chain, (less likely) rear sprocket, and brake shoes front and rear.
2005 Bonneville: 18 tooth sprocket, 135 Mains, 40 Pilots, 1 shim/Thruxton needles, no AI, K&N filters, Emgo Slip-Ons.
My Photo Album
2005 Bonneville 1968 BSA A65L
1972 Triumph TR6R
psasak is offline   Reply With Quote
Old 11-19-2009, 01:04 AM   #5 (permalink)
Hey, my list was ONLY the engine!
GrandPaulZ
Born Again Bikes
My Photo album
Old 11-19-2009, 03:45 AM   #6 (permalink)
Adding all this to the grocery list...
Old 11-19-2009, 11:38 AM   #7 (permalink)
Favourite Bike: '68 TR6R
68TR6R's Avatar
Other Motorcycle: 1978 suzuki 125
In addition to:
Possibly cams
Lifters/followers
tappet blocks
Cam bushes
pushrods
various fasteners
oil pump
68TR6R is offline   Reply With Quote
Old 11-19-2009, 12:07 PM   #8 (permalink)
68TR6R, those parts you list are all core components, not typical replacement items.
I've never had an engine so clapped out that it needed new cam bushings. I've changed out a few for clients, but they typically get great wear on Triumphs.
It takes a LOT to hurt a cam, and the followers can have the flat spot re-ground 99% of the time, no need for new ones.
Oil pumps typically last many years as well...
GrandPaulZ
Born Again Bikes
My Photo album
Old 11-19-2009, 02:32 PM   #9 (permalink)
Favourite Bike: 1968 Triumph Bonneville
Other Motorcycle: 2008 Harley Fat Bob
Good thread lads.
Couple questions: 5 piece seal kit - what seals are these GPZ?
ALso OPRV - is that oil pump ? valve?
I suppose the big variable (and why they dont put kits together) is whether any of the components are "over" standard clearances. E.g. piston, rings, crank bearings, bushings. Ive seen gearbox kits but never engine/crank kits.
Cheers.
Kev_England is offline   Reply With Quote
Old 11-19-2009, 04:09 PM   #10 (permalink)
Favourite Bike: 67 TR6C
looseparts's Avatar
Other Motorcycle: 06 Kawasaki VN900
Extra Motorcycle: 73 Yamaha DT3
See?
See? I told you these guys would be fantastic help!
The 'total rebuild kit' was the first thing I search on, because I too had saved a ton of cash going that route on some Brit motor car rebuilds, but part way through the tear down on the rusty 500 showed that it was only rusty on the outside. Inside there was minor wear on many components - so a 'kit' would have been overkill.
Gotta be hard working it all out 10,000 miles away - get home soon - the fun awaits : -)
looseparts is offline   Reply With Quote
Member Photos - 650cc Unit Twins - 1963-1970 GleaminTwin Classic, Vintage & Veteran Photos 313 12-16-2011 01:04 AM
Member Photos - Pre-Unit 650cc models Red1959 Classic, Vintage & Veteran Photos 155 08-04-2011 04:18 AM
English 101 DVD - unit & pre unit Triumph & unit BSA Motorcycle Maintenance DVD lowbrowcustoms Maintenance & Workshop Talk 2 08-23-2009 03:48 AM
Unit 650 rebuild video Billdozer Classic, Vintage & Veteran 20 03-11-2007 02:28 PM
Triumph 650cc Unit Construction Engine Overhaul Manual YD Twins Talk 3 09-07-2005 08:00 PM
