wheel offset ? - Triumph Forum: Triumph Rat Motorcycle Forums
Ontario TourismMotorcycle.comNew Bonneville
Old 11-18-2009, 05:11 PM   #1 (permalink)
Favourite Bike: 76 bonneville
wheel offset ?
hey guys how is everyone ?
why is the rear wheel offset to the drive side on my 76 bonneville ?
can i run radial tires ? i was at a bikeshop today and they said i should only run bias ply. what the ? .....anyone.
bullittprod is offline   Reply With Quote
Old 11-18-2009, 06:36 PM   #2 (permalink)
Favourite Bike: '67 Triumph Bonneville
The wheel should be centered in the chassis.
You should look into Dunlop 501 GTs or Avon AM26 RoadRiders.
GrandPaulZ
Author of "Old Bikes"
Born Again Bikes
My Photo album
Old 11-18-2009, 06:48 PM   #3 (permalink)
i have read some stuff on here about wheel offsets. why would mine be offset ?
Old 11-18-2009, 07:04 PM   #4 (permalink)
Probably incorrectly laced, or spacers installed wong in the axle setup. Is your drive chain aligned with the engine sprocket? If it's not, that's another telltale sign, and means you are eating chain & spockets every mile you drive.
Could be the rear end got whumped by a car, also...
GrandPaulZ
Born Again Bikes
My Photo album
Old 11-18-2009, 08:08 PM   #5 (permalink)
Favourite Bike: 62'DBD34
Other Motorcycle: 1970 Morgo T120
Extra Motorcycle: Classic Sidecar Outfit
Not to mention the power loss and camel-like handling.
NickL is offline   Reply With Quote
Old 11-19-2009, 02:19 PM   #6 (permalink)
Favourite Bike: '68' T120 Bonneville
Other Motorcycle: 2006 T100 Bonneville
Extra Motorcycle: '79' T140 street tracker
The rear fender is not in line with the center of the bike. That sometimes gives the illusion that the rear wheel is off center?
jimmy bush is offline   Reply With Quote
Old 11-19-2009, 02:23 PM   #7 (permalink)
it dose'nt have a rear fender ,and by eyeballing it it looks to be offset by about 1/2 to 3/4 of an inch.
Old 11-19-2009, 02:57 PM   #8 (permalink)
Favourite Bike: 1977 T140V
Ohio-Rider's Avatar
Other Motorcycle: 1949 Ariel SQ4
Extra Motorcycle: 1945 WL (Civilian)
I believe Pauls got it right. Are you working on a basket case and maybe just had a new wheels laced up? Have you recently split the rear hub apart? -Steve
Ohio-Rider is offline   Reply With Quote
Old 11-19-2009, 03:45 PM   #9 (permalink)
no its not a basket case. but i should mention that it has about 5 broken spokes on the disc side. would that pull the wheel over to the drive side ?
Old 11-20-2009, 07:12 AM   #10 (permalink)
Favourite Bike: T140 E
I would have thought that that'd do it.
You don't ride it like that do you?
DAVE M is offline   Reply With Quote
non offset aftermarket pegs available? braindead0 Sprint Forum 7 09-17-2009 10:22 PM
Offset front sprocket Nick1000 Twins Technical Talk 2 06-06-2009 04:42 PM
Do you have LSL Offset Match clipons?... LBS3 Speed Triple Forum 2 06-14-2008 03:16 PM
LSL Offset Clip-ons for Thruxton foggydewhearst Club Cafe' 9 09-24-2006 06:10 PM
TBS v Tbird fork offset Bodger Hinckley Classic Triples 14 07-27-2006 11:37 PM
