Originally Posted by valiantbultaco
twin 30mm vm brand new
http://www.jba.bc.ca/Bushmans%20Carb...g.html#SYNCHRO
A nice read here, but based on the VM 32 unit. However, Mikuni
needles have more than enough adjustment in them (5 notches in-
stead of 3) you should have no problems with useing these number
in a 30 unit. Just stay on the lower end.
And a personal note, I found the main jet numbers that are given
to be way to big. I had to go much smaller. But this is something
you have to work on a little at a time. Better to be rich and lean.
Pookybear
