Chain adjustment on 71 OIF Bonnie?
On this bike is a bar bolted to the swing arm area and then to the rear hub, left hand side,this was not there on my last Triumph?
Anyway I obviously have to unbolt this bar to adjust the chain,but if I tighten the chain the hub will move backwards, how will the bar still fit if it has two fixed points with no adjustment in the bar?
Thanks,Den
