| Classic, Vintage & Veteran For Coventry and Meriden Models. Anything pre-Hinckley goes. |
11-14-2009, 10:36 PM
Amal Carb Questions
Looking at the carbs on my 69 T120 I notice when I pull the throttle cable the slides move up but the air valve doesn't move, it sits there. What's the purpose of the air valve, should it not move with the slide?
11-14-2009, 10:43 PM
Supersport 600 Favourite Bike: 62'DBD34
Posts: 154 Other Motorcycle: 1970 Morgo T120 Extra Motorcycle: Classic Sidecar Outfit
take the air/choke slides out and blank the cable holes with a couple of small nuts and bolts. They are not required and just cause problems.
Nick
11-14-2009, 10:50 PM
There are no cables to the air sides! It just sits there. Posssibly I'm missing something from the carbs. I don't see a cable hole for the air slide. I'll remove them.
11-14-2009, 11:03 PM
Formula Extreme Favourite Bike: Mine
The air valve is the 'choke'. If they are still there, the choke lever should still be on the handlebars ... you may be looking at it wrong ... cable 'relaxed' is choked (air valve 'down' and blocking a portion of the air entering the carb) ... cable 'taut' is normal run position (air valve up and out of the way allowing all the air to enter the carb). Except in really cold weather, you should be fine without a choke. As stated before, just remove the air valves (and their associated spring, etc) and seal the hole in the top of the carbs where their cables would have gone through.
11-15-2009, 12:02 AM
Formula Extreme Favourite Bike: 1959 Triumph TR6
Posts: 730 Other Motorcycle: 2003 HD Road King Police
It probably looks like You do not have a cable hole because the choke cable holder may have already been replaced with a screw/ nut. Do you have Monobloc or Concentric carb?
Reason: spelling
11-15-2009, 06:15 AM
Amal 930 Concentric carbs. The air slide sitting there is probably why I'm having starting problems.
11-15-2009, 10:07 AM
SuperBike Favourite Bike: '68' T120 Bonneville
Posts: 1,721 Other Motorcycle: 2006 T100 Bonneville Extra Motorcycle: '79' T140 street tracker
If you get it started it will cause it to run really rich when it wets warmed up. Some bikes run fine without the air valves, some, like my 68 T120, won't run for doodly until they get warm unless the air valves are closed a bit.
11-15-2009, 10:31 AM
As I don't have a choke cable, I removed the air valves and plugged the hole with a bolt/nut, hopefully she'll start today !!
11-15-2009, 12:05 PM
Minitwins Favourite Bike: 1977 TR7V
I'm with Nick L take the air slides out. You don't need them if you have ticklers on the carbs. Plug the hole for the cable with something. Bike will run horribly rich with chokes on all the time.
11-15-2009, 02:12 PM
World SuperBike Favourite Bike: T120V
The chokes were not fitted to mine.
Filled the top holes with silicon filler.
