Originally Posted by Topher
Hi All,
Just got back from a 200 mile trip up the coast on my Tiger. It was an amazing ride however on the trip home some vibration issues started in. First the tabs that hold my ignition side panel on broke off. No problem, I took some bungee cables with and was glad I did.
After completing this road side task I noticed the ignition lights wouldn't illuminate with the ignition on. I figured something had wiggled loose in the ignition panel when it broke. But all the connections were fine and the bike still kicked right over and I was able to get home.
Once home the ignition went completely dead. The wiring under the engine where the harness is held to the crankcase had rubbed through and the wires were exposed. The problem is the wires are broken right at the point where they enter the hard outer cable. Any tips on how to fix these would be much appreciated. It seems impossible to strip any outer cable away without damaging the wires as they are packed in tight.
Also, I'd like to weld the side panel but I have never welded. Feasible? Or would picking up another panel be cheaper?
Thanks! -topher-
Topher,
Well no one has picked this one up and I would say it is because
no one is getting the mental picture of what you are asking.
So easy one first, welding, if you have not done it before, just
buy a used part on Ebay. Nice looking and strong welds are some-
thing that just does not happen right away.
Second problem, I can not quite picture the wire with the outer
case unless you are talking about the stator wires. Either way,
you can take a small manicure scissors and snipe up the outer
cover say about and inch or so. The small sicssors shall give you
the control needed as not to damage the wire any further. You
should be able to get the one point of the scissor into the end
of the case between some of the wires.
I hope this helps you out,
Pookybear
