66 650 twin misfire trouble - Triumph Forum: Triumph Rat Motorcycle Forums
Old 11-14-2009, 04:23 PM   #1 (permalink)
Newbie
i have a 66 650 that i just got running again after a while heres my story...
when it runs. one cylinder fires and the also gets really hot really fast....the other cylinder dooesnt fire and the carb blows out air....dual amal carbs....it has spark (boyer), cleaned the plugs up they were all black... i have no idea please help
Thanks
pete
ratdntatd is offline   Reply With Quote
Old 11-14-2009, 06:22 PM   #2 (permalink)
Favourite Bike: '68' T120 Bonneville
Other Motorcycle: 2006 T100 Bonneville
Extra Motorcycle: '79' T140 street tracker
If the bike has sat for several months, there is a good possibility the gas in the carbs has turned to green varnish stopping up some jets and passageways. Swap sides with the plugs to see it the plug is fouled. How is the compression on the dead cylinder. May have a stuck valve or rings.
jimmy bush is offline   Reply With Quote
Old 11-14-2009, 06:43 PM   #3 (permalink)
Newbie
ok ill go buy a compression tester at harbor frieght what numbers should it read..
i took off the float bowls and checked them seemed fine dont know exactly what to look for but they werent stuck or broken or anything
Old 11-14-2009, 08:50 PM   #4 (permalink)
You can do an impromptu compression check with your thumb. pull your spark plugs and press your thumb over the hole as tight as you can. Kick or have some one kick the bike over briskly with the ignition off and the throttle open. You shouldn't be able to hold the pressure back with your thumb. If you can, there is your problem. It doesn't tell how much but does tell if there is some compression. Boyers like a fully charged battery to run correctly. Make sure yours is charged. Since you're running a Boyer, you could swap the plug leads and see if the problem goes to the other side. If it does, check all associated electrical connections. If they are good,and the battery is good, you may have a bad coil.
Old 11-14-2009, 09:36 PM   #5 (permalink)
Newbie
compression on not working cylinder is:
1st kick 30...second 60 ...third 95 where it stays
copmression on working cylinder:
2 kick 30 ...4 or 5th kick 70 where it stays
is that good
Old 11-14-2009, 10:18 PM   #6 (permalink)
Favourite Bike: 62'DBD34
Other Motorcycle: 1970 Morgo T120
Extra Motorcycle: Classic Sidecar Outfit
Check the spark on both cyls you may have a duff coil or lead etc.
NickL is offline   Reply With Quote
Old 11-15-2009, 01:09 AM   #7 (permalink)
Did you hold the throttles wide open when you kicked it for a compression test. If not, you didn't get the true reading.
Old 11-16-2009, 12:16 PM   #8 (permalink)
Favourite Bike: '67 Triumph Bonneville
Before you go pulling the engine apart, do a thorough maintenance, by the book, front to back, top to bottom, side to side.
The book lists the procedures in a particular order, because each step requires other things be in order BEFORE proceeeding to the next.
(sounds like a simple valve adjustment issue, though...)
GrandPaulZ
Author of "Old Bikes"
Born Again Bikes
My Photo album
What is the power delivery difference between a Vertical Twin and V Twin worldspeaker Twins Talk 59 12-24-2011 04:09 PM
1962 Triumph 5TA speed twin - Wiring trouble Jolly5TA Classic, Vintage & Veteran 5 07-31-2009 09:57 PM
How about a hinkley version twin/twin thruxtonone Twins Talk 12 08-11-2005 08:42 AM
Trouble starting, misfire at high rpm's 97Daytona Daytona Deliberations 1 07-06-2005 11:31 AM
misfire Sprint Forum 5 01-18-2005 08:44 AM
