Rogue Red wire sprouting from new wire harness - Triumph Forum: Triumph Rat Motorcycle Forums
Motorcycle.com Classifieds!Motorcycle.comOntario TourismSportbikeTrackGear
Old 11-13-2009, 05:42 PM   #1 (permalink)
Favourite Bike: 1968 Triumph Bonneville
Other Motorcycle: 2008 Harley Fat Bob
Help!
A couple of us are having a difficult time figuring out exactly what purpose a lone, gangling, rogue red (earth) wire is doing on our lovely new English cloth harnesses. There's nowt in any diagram to indicate the purpose of this wire.
Please see picture below and note the red wire opposite the alternator wire. My bike is a 68 Bonnie and apparently, said wire is also appearing on 70 Bonnie harnesses.
Where should the loop connector and truncated wire connect to?
Kev_England is offline   Reply With Quote
Old 11-13-2009, 07:39 PM   #2 (permalink)
On my 70 Bonne (original harness still in place) the ring connector is attached to one of the studs that hold the oil tank; the end goes to the positive side of the battery.
HTH
jim
old70bonne is offline   Reply With Quote
Old 11-13-2009, 08:47 PM   #3 (permalink)
HTH
jim
Many thanks Jim - is the ring attached to one of the top lugs of the oil tank? Also, you mean the bare wire earth is just wrapped around the battery positve terminal?
THanks again mate.
Old 11-13-2009, 09:46 PM   #4 (permalink)
Your harness lacks a connector at the end. My harness has connector that enables me to attach it to the battery via the supplied battery bolts/ nuts.
Old 11-13-2009, 10:05 PM   #5 (permalink)
Kev,
I am going from memory (not near my bikes) but I believe that in your pic that you posted above what you have labeled + battery is actually the ground to your rectifier. The red wire is the postive connection to your battery. It should have a similar connector to the wire you have (correctly) labeled - battery.
I'm by no means an expert, but that is what I remember from my bike, which is unaltered.
Old 11-14-2009, 09:38 AM   #6 (permalink)
Favourite Bike: '67 Triumph Bonneville
Several points should be wired to ground/earth at various points on the frame:
-Battery positive (+) terminal
-a specific point in the ignition coil wiring (refer to your ignition system diagram)
-Rectifier stud and/or top tab connector
-thin terminal of 2MC capacitor, if used
-headlight shell
-engine (sometimes at the head area, and/or crankcase bolt/nut)
-rear fender (provides ground path for tail light)
-Zener Diode base
I may be missing one or two points...
GrandPaulZ
Author of "Old Bikes"
Born Again Bikes
My Photo album
Old 11-15-2009, 10:14 AM   #7 (permalink)
Kev,
Many thanks Old70 - that does make sense since the ground wire is the same length as the rectifer wire - I should have guessed that!
Makes sense too that my mystery red wire hooks to the battery.
GPZ - as usual many thanks for your input! Im wondering if my chopped ground wire is the ground you refer to that goes to the engine somewhere? I seem to recal a picture of an engine and seeing a stray wire like my mystery one grounding to it? Or am I barking up the wrong tree?
My main concern is that I havent been sold a "New" harness that's been molested (i.e. the chopped ground wire).
Cheers.
Old 11-15-2009, 07:36 PM   #8 (permalink)
Favourite Bike: 1976 Triumph TR7RV
NJTiger's Avatar
Other Motorcycle: 2004 Harley Electra Glide
Extra Motorcycle: 1971 BSA Thunderbolt
Hey Kev,
where did you get that harness?
NJTiger is offline   Reply With Quote
Old 11-16-2009, 08:51 AM   #9 (permalink)
Originally Posted by NJTiger View Post
Hey Kev,
Bought it from Klempfs British Supply. Supposedly one of the best suppliers out there. I even bought the "best he had" which was $200.
If I cannot find anyone who knows what that stray red wire is for I think ill be giving Mitch a call!
Old 11-16-2009, 12:02 PM   #10 (permalink)
Just attach an appropriate eyelet terminal to it and bolt it up to the nearest, cleanest spot on the engine.
GrandPaulZ
Born Again Bikes
My Photo album
wire harness hikinghome Tiger Workshop (archive) 2 07-14-2009 04:40 AM
New Wire Harness Help - 68 Bonnie MNTriGuy Classic, Vintage & Veteran 2 02-04-2009 12:59 AM
Wire Harness Experts MNTriGuy Classic, Vintage & Veteran 1 12-07-2008 07:23 PM
'78 T140E US wire harness motersikelist Classic, Vintage & Veteran 1 08-28-2006 01:13 PM
Extra Wire/harness? cracKness T3 Sport / Touring Forum 4 12-26-2005 09:26 PM
