blinker wont blink 1978 bonnie
I have a 1978 bonnie I am new to working on bikes and so far have done everything on my own short of bringing it in to a mechanic to do a once over. witch did not turn out to well the mecanic was awsome and helped me alot showed me what I needed to do exactly the type of help I was looking for. But when he put the battery back in he left the negative wire prong up not to far but just enough so I was driving on the way home did not notice it hit a bump and the bike staled. At the time I figured the the carb adjustments we did was part of that so I didled with them and got the bike going. I got a little farther down the road hit another bump and stuff started smoking. That is when I poped the seat and noticed the wiring smoking and the arc mark on the bottom of the seat. I called the guy he came by helped me change some wires got it going did not have a fuse available so had to use a small piece of metal. I got the bike home fine replaced the fuse and all was well for awhile. a few days later I was going to work and blew a fuse I repalced it got to work. On the way home it did it again found out there was a little spot of wire on the blinker line that was shaved so I fixed that had to rig the fuse to get it home. now I can not get the bike to start or the blinkers to blink they both work but wont blink what should I check is there a easy way to check the wires? where should I start I am new to this and got the bike not to long ago so I am still getting the feeling for it any help would be appreciated
vancuzo
