Installing chrome strips on gas tank 1971 - Triumph Forum: Triumph Rat Motorcycle Forums
post #1 of 7 (permalink) Old 10-28-2009, 02:00 AM Thread Starter
Main Motorcycle: 1971 TR6R Routts 750
Landshark's Avatar
Have new chrome strips for OIF 1971 TR6R gas tank. Question, to keep the chrome strips secure to the raised center ridge does the spade end that goes in the slot under the tank get bent back to stay secure? I see how it is secured at the plug that connects the front and rear strips, but the other ends will not stay down.
Thanks
Bob
Landshark is offline
post #2 of 7 (permalink) Old 10-28-2009, 08:45 AM
Main Motorcycle: 06 Thruxton
Other Motorcycle: '69 Bonneville
Extra Motorcycle: '71 Bonneville
Hi Bob,
Yea, that’s the way mine is. Just pushed through and folded back on it’s self.
Art
BirdoPrey is offline
post #3 of 7 (permalink) Old 10-28-2009, 09:40 PM
Main Motorcycle: The one between my legs
Snakeoil's Avatar
Other Motorcycle: A few
Extra Motorcycle: Yes
I've heard various stories about how well these strips stay in place, now they break due to vibes, etc.. I have a '66 that will get restored soon and keeping that strip in place and reducing the chance of breakage will be something I'll be looking at. I've been thinking that perhaps a bead of silicone or 3M 5200 down the inside of the strip before installing might keep it from vibrating itself to death or at least prolong it's life. I would think that 3M 5200 would even keep it in place after the ends had cracked.
Anyone have experience or suggestions for this strip?
Thanks,
Rob
Snakeoil is offline
post #4 of 7 (permalink) Old 10-28-2009, 10:11 PM
I’ve never really had a problem with the strip on my ’69, It attaches differently than my ’71. The ’69 attaches with the little loop at the rear while the ’71 slips into a slot under the tank. Are the ‘66s different than the ’69 or was I just lucky enough not to have a problem?
Art.
post #5 of 7 (permalink) Old 10-28-2009, 10:42 PM Thread Starter
Landshark's Avatar
Thanks for the comments, I think I will try a bead of auto weather stripping adhesive. It will be awhile before I do that as I have to grind off the mess the PO did on the top of the tube to jury rig a fastener for the main bolt down the center.
post #6 of 7 (permalink) Old 10-29-2009, 09:46 AM
Snakeoil's Avatar
Art.
'66 attaches same as your '69. My friend's is currently held on with a zip tie.
There was another version that had a threaded stud spot welded to the strip, instead of the eyebolt arrangement. Problem with that design is when the stud fails, you can't fix it unless you weld something to the strip.
Even all metal motorcycles have their weak points. But at least I can fix metal.
Rob
Snakeoil is offline
post #7 of 7 (permalink) Old 10-31-2009, 05:26 PM
Other Motorcycle: Triumph Speedtriple
Mine are just folded over at both ends, but I still found they were still a bit loose, a thin bead of clear RTV between the tank and the strip seems to have stuck them in place.
Webby
Webby is offline
Installing Chrome Cam Cover kgood Air Cooled Twins Technical Talk 17 02-15-2012 01:43 PM
Help installing new tach and clutch cable 1971 TR6R Landshark Classic, Vintage & Veteran 3 08-29-2009 11:37 PM
Installing knee pads to tank jonathanrsr Club Cafe' 2 10-28-2008 05:51 PM
chrome tank strips miley800 Air Cooled Twins Talk 3 04-03-2008 08:15 AM
Chrome strips on new Bonnie tanks EnglishBaz Air Cooled Twins Talk 10 04-04-2006 06:19 PM
