Triumph Engine Numbers Help!!!!!!!! - Triumph Forum: Triumph Rat Motorcycle Forums
post #1 of 5 (permalink) Old 10-13-2009, 09:23 PM Thread Starter
Main Motorcycle: 64 tr6
Hi everyone, I have recently got hold of a triumph twin engine and dont really know what I have. My experience with Triumphs has basically been installing sparx electronic ignitions on T120R motors. Two of them to be exact. The engine that I have now has the engine numbers TR6 DU14107. I have done a little research and believe it to be a 1965 model but am not sure. Is this engine a 650. Would it be a Tiger, Trophy or Bonneville. What is the difference between the TR6 & T120R. I am needing to get some parts for this engine and would like to know what I have before I begin ordering. All that I have is the engine and I will be installing an electronic ignition on this item and placing it in a custom frame. Can parts from different engines be innerchanged on some models. I am also a little confused about unit and pre unit. Thanks in advance and any help and advice would be greatly appreciated.
Eric (excalibrator)
P.S. My knowledge of electronic ignitions for Triumphs came from this site. Thanks to all!!!!!!!!!!!!!!!!!!
EXCALIBRATOR is offline
post #2 of 5 (permalink) Old 10-13-2009, 09:55 PM
Main Motorcycle: all 5 bikes for now
old bill's Avatar
Other Motorcycle: 72 tri,75 xs650,76 gl1000
Extra Motorcycle: 84 gl1200,05 sportster
i show early 1965 tr6 1 carb t120r 2 carbs
old bill is offline
post #3 of 5 (permalink) Old 10-14-2009, 12:34 AM
Legend
Almost any Triumph 650 parts will interchange between 65 and 70.
TR6 & T120 (Bonny) swapping stuff is a no-brainer.
GrandPaulZ
Author of "Old Bikes"
Born Again Bikes
My Photo album
GrandPaulZ is offline
post #4 of 5 (permalink) Old 10-14-2009, 05:15 AM
Main Motorcycle: 1971 Rob North Trident
Other Motorcycle: T150V Slippery Sam replic
Extra Motorcycle: 1969 T150T
Hi Eric,
It's a 1965 Trophy 650cc.
Differences from the T120R (Bonneville) are :-
Cylinder Head, (T120R has twin carbs)
Camshafts.
Pistons (T120 has higher compression ratio)
No tachometer drive. (although you could fit one)
'Unit construction' means that the engine and gears are in one unit, ie they are contained in the same casing. 'Pre-unit' literally means 'before-unit construction' The gearbox is a totally seperate item from the engine.
Andy.
Slippery Sam is offline
post #5 of 5 (permalink) Old 10-14-2009, 01:37 PM Thread Starter
engine numbers
Originally Posted by Slippery Sam View Post
Hi Eric,
Camshafts.
Andy.
Thanks Andy, The info you have provided is greatly appreciated. Best wishes, Excalibrator
Engine Serial Numbers Bluetiger901 Maintenance & Workshop Talk 3 02-10-2011 10:50 PM
Engine / Chassis Numbers Kegs Sprint Forum 3 08-30-2009 04:11 PM
Engine Numbers robmac Classic, Vintage & Veteran 3 05-05-2008 04:41 PM
5t engine numbers? 65bonnie Classic, Vintage & Veteran 2 04-01-2005 05:32 AM
engine and vin numbers DEN Triumph, Models & Dealers 4 04-08-2004 10:25 PM
