piston ring question
I have an econo set ready to be put in - but the problems begin there. No markings.... NONE!
the top two are identical with a chamfer on the inside (piston side) and the oil scraper is the one piece with a spring inside but, despite being identical on the outside, one of the inside edges is thicker than the other. Seems like there should be a specific order and direction to each, but damned if I can tell.
I suspect chamfer up for top, then down for 2nd, but have no idea for the oil ring. This would seem to be the standard for most automotive rings installations I could find on the internet - but I had a few locals saying both the same direction or it doesn't matter.
should i just get a set of hepolites instead?
cheers
