Tail Lamp "extension" wire for 68 Bonnie
Im in the process of fitting a new tail lamp. I bought my bike as a basket case. The built in wires from the lamp dont stretch far enough under the rear mudguard to then loop back up under the mudguard up into the seat area.
However, i see in the parts book a "Tail lamp lead".
Is this an extension that runs under the mudguard to connect the lamp leads to the main harness?
Makes sense but just wanted to check. I bought a cheap asian replacement lens so bit worried its like the asian Horn switch I bought that had short wires that didnt reach the headlamp.
Cheers, Kevin
