What is procedure for engine/oil flush? - Triumph Forum: Triumph Rat Motorcycle Forums
Old 09-13-2009, 03:36 AM   #1 (permalink)
Favourite Bike: 1971 TR6R Routts 750
Landshark's Avatar
I have an OIF 71 Tiger, no history and there was some work on that involved barrel being removed. I was told it would be a good idea to flush the engine.
Is it as simple as pouring some Kerosene in the case (barrel off) then removing the drain plug. Repeat except using a cheapo oil. The replace plug and fill normally? Same procedure for the oil in the frame tank?
Thanks
Bob
Landshark is offline   Reply With Quote
Old 09-13-2009, 05:11 AM   #2 (permalink)
Favourite Bike: 1971 t120r
Other Motorcycle: triumph rocket 111
Extra Motorcycle: suzuki m1800r
if you have no history,i would take the frame sump plate off and clean the mesh filter plus remove the crankcase plug and clean the filter in there.i never flush mine out.
try using mobil 1 20/50 vee twin oil in it.i brought some back from america as its not sold in the uk.
rambo is offline   Reply With Quote
Old 09-13-2009, 11:40 AM   #3 (permalink)
Favourite Bike: T120V
Caulky's Avatar
If the barrels are off, a simple flush like that, only flushes the sump.
The whole system really ought to be flushed.
Because I had lumps of metal and other stuff in mine.
I did what rambo said and also removed the oil-pressure relief valve.
And the oil pump.
Cleaned all with paraffin and refitted.
I filled the tank/frame with paraffin, left it overnight and drained it for a day.
Then I filled the system with cheap thin oil and primed the sump.
Plugs out, a few kicks to ensure the return is working.
Then filled with pukka oil.
Nice clean system
Caulky is online now   Reply With Quote
Old 09-13-2009, 02:28 PM   #4 (permalink)
Landshark's Avatar
Thanks for in advice, I had removed the sump, drain and pressure value and cleaned. Good idea to leave the paraffin (kerosene) in overnight then drain.
Thanks guys.
Bob
Engine Flush dblhelx Speed Triple Forum 2 11-17-2007 02:34 AM
Dental Procedure mdgore Triumph SuperSports 3 08-19-2007 09:20 PM
Run in procedure Trumpy1050 Speed Triple Forum 16 11-21-2006 07:50 AM
Engine Flush Treatments? Northern650Twin Classic, Vintage & Veteran 16 05-03-2005 11:04 PM
Engine Flush? bobshields55 Maintenance & Workshop Talk 10 03-21-2005 06:07 PM
