79 T140 engine sprocket - Triumph Forum: Triumph Rat Motorcycle Forums
SportbikeTrackGear
Old 09-12-2009, 01:40 PM   #1 (permalink)
I am isolating the primary case from the crankcase oiling and was wondering if anyone made a engine sprocket that was machined for the crankshaft seal?
If not does anyone know if I can run a 650 sprocket with a dual row chain to my 750 clutch basket? (leaving one set of teeth unused?)
thanks
Snakepit is offline   Reply With Quote
T140 front sprocket problem. gumpt1oo Classic, Vintage & Veteran 5 08-02-2009 07:06 PM
t140 engine tear down questions scatdawg Classic, Vintage & Veteran 6 04-14-2009 10:42 PM
t140 engine leaks, help... retro59 Classic, Vintage & Veteran 3 01-14-2009 09:20 PM
1979 T140 - What engine oil???? green_machine Classic, Vintage & Veteran 18 10-30-2008 02:03 PM
1967 frame and T140 engine need parts or value meangene1975 Classic, Vintage & Veteran 18 04-16-2008 10:30 PM
