Newbie Needs Help... - Triumph Forum: Triumph Rat Motorcycle Forums
Old 09-11-2009, 05:05 PM   #1 (permalink)
Favourite Bike: 73' 750
sLoRide's Avatar
I bought a 73' Tiger 750 a couple months ago. I've been tinkering with it -cleaning the carb, changed fuel lines, flushed the tank, and other minor tune-ups. but I have some problems...
My carb setup is a single Amal concentric carb with a 260 main jet.
Problems/Questions:
1. My plugs are char black (running too rich), Is my main jet too large? should I have a 240?
2. I start the bike with the choke lever in the down position, I think this is the off position because the choke slide located inside the throttle slide is all the way up when the lever is down. -Is this the correct setup for the choke to work? It looks like someone has messed with the cable.
3. After the bike runs for a while or if I go for a short ride down the drive, the engine side of the throttle slide has black/brown sticky stuff on it, and if it continues to build up it makes the throttle slide stick. Do my valves need to be adjusted? It seems like unburned fuel is escaping the cylinder and coming back out the intake...any thoughts?
Thanks for any kind of help...I need it.
sLoRide is offline   Reply With Quote
Old 09-11-2009, 06:42 PM   #2 (permalink)
bum
If it's like a Mikuni the choke is off when the lever is up. (the plunger is down)
bum is offline   Reply With Quote
Old 09-11-2009, 06:45 PM   #3 (permalink)
bum
Sorry sloride. I didn't realize you were talking about the lever on the handlebars. My mistake.
Old 09-11-2009, 06:49 PM   #4 (permalink)
Favourite Bike: 1976 Triumph T-140V
thirdbike's Avatar
Other Motorcycle: 1950 Matchless G80
Extra Motorcycle: Yamaha 1200
Your manual calls for a 280 main with a 106 needle jet. These and the needle may be badly worn causing the rich mixture
Your choke is on when the choke slides are down inside the carb throat blocking the airflow so as to enrich the mixture.
The cable holds the choke open for normal running.
If you have fuel/exhaust residue deposits in the carb, your bije cannot be running too well if at all. Your valve timing may be off but unlikely. It may be that you are in dire need of a valve job.
To prevent further damage, you probably shouldn't be running the bike with these reported conditions
thirdbike is offline   Reply With Quote
Old 09-11-2009, 09:12 PM   #5 (permalink)
Favourite Bike: pre '68 Bonneville 750cc
Other Motorcycle: 86 Yamaha FJ1100
Extra Motorcycle: Custom mini-bike 165cc
I too have a 73 750 Tiger single carb and have been stuggling with it. My advise is to buy a new .106 needle jet, a new needle, and even a new needle clip. These are the three things that helped me the most. I would also make sure the float level is set to around .080. Also what size slide do you have. Mine is a 3-1/2.
On the choke level you can determine the setting but opening the throttle a little(motor off) and stick you finger in the carb. Now work the choke lever back and forth and see which way it goes.
From your description of the throttle slide being black, and you plugs charred, I surely need a new needle jet if nothing else.
TangoMike
If it's not leaking oil, there ain't none in it.
tangomike is offline   Reply With Quote
Old 09-12-2009, 02:53 PM   #6 (permalink)
sLoRide's Avatar
Thanks for the feedback, I think I will go with ordering the new needle and jets, and while I'm waiting for them to show I can pop the top and check the valves. -Any suggestions as to where to buy carb parts?
Old 09-12-2009, 03:48 PM   #7 (permalink)
sLoRide's Avatar
I just finished reading another thread about a bike backfiring through the carb, indicating that the timing is too advanced. Mine doesn't backfire through the carb frequently, but it has a couple times while I was tuning (or trying to) the carb. - any thoughts?
All will die, few are those who LIVE.
Old 09-13-2009, 10:07 AM   #8 (permalink)
Thoughts? The scientist in me thinks like this. A pop or backfire thru the carb is an obvious indication that fuel has ignited outside the cylinder chamber. With that in mind, how does it happen? Timing, period. Fuel cannot ignite outside the cylinder chamber if the "timing" is correct. But that does not me the timing is out. (What did he just say??) Another way the timing(of the fuel iginiting) retards ever so slightly, is the delay of fuel ignition. This is common to all internal combustion engines, not just old Triumphs. It is the same principle as the physical timing being off. The fuel does not ignite or does not ignite completely until the exhaust valve is closed and the intake valve is open or partly open. If you get a little pop or backfire thru the carb while tuning, this is very normal. My advise is to CHECK the timing, but don't get too hung up on it, just make sure it is right. Your real problem may just be only a worm needle jet. The jet is brass and the needle is stainless steel so the jet wear out first.
My thoughts.
TangoMike
Old 09-13-2009, 04:43 PM   #9 (permalink)
sLoRide's Avatar
Thanks, Tango
As a general rule of mine I like to try the simplest solutions first, so I will definatly be ordering a needle and jets. If this dosen't do the trick, my next suspiscion is my plugs need to be hotter (this is also suggested by the manual), any thoughts on this (makes me feel all scientific now. ha)
Old 09-14-2009, 04:17 PM   #10 (permalink)
Thanks, Tango
You did not mention what type ignition do you have?? Stock?? Mine is a Boyer.
TangoMike
newbie says hi and help! sparky955 Twins Technical Talk 4 01-04-2009 12:35 AM
Another UK Newbie........... Ventura Twins Talk 13 05-23-2008 02:55 AM
Newbie needs some help cmeisel Tiger Chat 12 07-24-2007 10:57 PM
newbie in the uk chipmunk The Rocket Science Forum 4 05-07-2007 06:03 PM
Newbie says Hi! Triplegeezer Daytona Deliberations 11 06-16-2006 03:45 AM
