Replacing Steering/Fork Lock Cylinder - Triumph Forum: Triumph Rat Motorcycle Forums
SportbikeTrackGear
SportbikeTrackGear
Old 09-10-2009, 10:55 PM   #1 (permalink)
Favourite Bike: 1971 TR6R Routts 750
Landshark's Avatar
I need help on procedure to remove steering or fork lock on my 1971 TR6R. I have a replacement with grub screw with a hex head. I believe once I have the old lock out, I put in the new lock and then install the new grub screw and knock off the hex head and push in the plug.
Do I have to take the handle bars off and remove headlight? It looks like the procedure would be to remove the headlight, drill out the plug and then what?
Any help would be appreaciated.
Thanks
Bob
Landshark is offline   Reply With Quote
Old 09-11-2009, 01:16 AM   #2 (permalink)
Favourite Bike: 1976 Triumph T-140V
thirdbike's Avatar
Other Motorcycle: 1950 Matchless G80
Extra Motorcycle: Yamaha 1200
Once the screw is out, you can simply knock out the old slug
thirdbike is offline   Reply With Quote
Old 09-11-2009, 03:58 AM   #3 (permalink)
Favourite Bike: Triumph Bonneville
Other Motorcycle: Triumph Speedtriple
Hi Landshark,
It would be a good idea to remove the headlight for access. When I replaced my lock, I simply drilled out the old grub screw with an undersize drill and then hammered a torx bit in the hole and unscrewed the remainder of the grub screw. (You could use an easyout if you have one to hand)
It's good you mentioned that you are meant to knock the hex head off the the bolt, I didn't know that, but now you've mentioned it, it seems obvious
Thanks
Webby
Webby is offline   Reply With Quote
Old 09-11-2009, 11:55 AM   #4 (permalink)
Landshark's Avatar
Thanks all, what had me sorta of stumped was I could not see that the existing grub screw had a slot for a small slot screw driver. The new grub screw I got had a hex or normal looking 6 sided bolt head. I understand once it is inplace, you knock off the head (connected by a thin stem to the screw). Once I had the headlight off and the thin metal cap drilled out (careful not to damage the threads inside) I saw the old grub screw had a slot, so it was simple to remove and then knock out the the old lock cylinder.
Replacing steering bearings? themaster Triumph SuperSports 10 05-27-2009 05:44 PM
Replacing the steering lock Toooldforlonghair Twins Technical Talk 5 04-05-2009 05:42 PM
Fork-lock cylinder pochie Classic, Vintage & Veteran 13 04-04-2008 10:13 PM
Steering way: Degrees of steering lock ChuckofTahoe Sprint Forum 9 09-02-2007 10:35 PM
Replacing fork lock cylinder on a 2003 Bonneville bfly Twins Talk 4 09-03-2005 12:56 PM
