Point-Type Ignition system (Kick Start no battery)) - Triumph Forum: Triumph Rat Motorcycle Forums
Motorcycle.comOntario TourismHonda PowersportsSportbikeTrackGear
Old 09-07-2009, 08:45 AM   #1 (permalink)
Gents-
Please look at the picture attached; I could really use some help configuring this correctly. I need to reinstall a new 12v coil and wanted to make sure everything is correct and then use a strobe light to time the bike….
Dean Nelson is offline   Reply With Quote
Old 09-07-2009, 12:30 PM   #2 (permalink)
Favourite Bike: 1976 Triumph T-140V
thirdbike's Avatar
Other Motorcycle: 1950 Matchless G80
Extra Motorcycle: Yamaha 1200
We Could Hazzard a Guess.
If you don't tell us what kind of bike, year, model, polarity, ignition system, modifications etc. etc., how do you expect to get sound advise? - Are we talking a prewar Harley or a competition trail bike.
thirdbike is offline   Reply With Quote
Old 09-07-2009, 12:58 PM   #3 (permalink)
Sorry Gents left out some information
My bike is a 1971 Daytona 500cc tr100
no battery kick start only
Old 09-07-2009, 10:45 PM   #4 (permalink)
Favourite Bike: '68' T120 Bonneville
Other Motorcycle: 2006 T100 Bonneville
Extra Motorcycle: '79' T140 street tracker
Are you going from 2 coils to 1. It looks like your diagram has two sets of points as with the two coil ignition. I don't think you can wire up both sets of points to one terminal and have it work right. I think you would need one set of points and a rotor with two lobes so it fires twice for each revolution of the cam to run the single coil. You smart guys correct me if I'm wrong.
jimmy bush is offline   Reply With Quote
Old 09-08-2009, 02:44 AM   #5 (permalink)
Favourite Bike: '72 Triumph TR6C
flypa38's Avatar
A single 12v coil works fine with both points. That's what I'm running! Not really a problem, but it does have what's known as a "wasted spark". Both plugs spark at the same time, but twice as often.
Check this out:
This is for a pos. ground.....
Hope this helps!
Johnny
flypa38 is offline   Reply With Quote
Old 09-08-2009, 11:17 AM   #6 (permalink)
OOps! my bad. Now that I visualize it, I can see how the points won't interfer with each other. For some reason, I was imagining the trailing set being colsed when the lead set would be opening thereby effectively shorting it out. The reality is they both would open and close while the other set was opened by the lobe so would work. Hey it was late when I was mulling it over. Sorry for the confusion.
Old 09-08-2009, 11:20 AM   #7 (permalink)
Favourite Bike: '67 Triumph Bonneville
Hey, flypa, that's a cool wiring diagram with pictorial bits!
GrandPaulZ
Author of "Old Bikes"
Born Again Bikes
My Photo album
Old 09-08-2009, 12:09 PM   #8 (permalink)
Points
So my points wired like this is ok?
Old 09-08-2009, 04:31 PM   #9 (permalink)
flypa38's Avatar
Got the wiring diagram from http://www.thehorsebc.com and they have others....
Looks like it'll work provided you have your terminals isolated from the studs using the nylon spacers. Looks like you have that right too from the picture.
My bike is pos. ground and I have the points and condensor on the pos. coil terminal.
Pretty sure neg. ground would be opposite.
Johnny
P.S. Jimmy, I was kind of thinking the same thing and was wondering if strobe timing would still work. Had to go turn the engine over slowly and watch it all happen in slow-mo to understand it!
Points - type ignition system (kick start no battery) Dean Nelson Maintenance & Workshop Talk 1 09-07-2009 07:39 AM
battery weak had to kick off knapper The Rocket Science Forum 4 08-29-2009 01:54 AM
Kick start won't rotate tbox35 Classic, Vintage & Veteran 8 05-13-2008 11:10 AM
kick start reyals140 Classic, Vintage & Veteran 11 03-10-2008 08:01 PM
Kick start bbx45lc Twins Technical Talk 7 11-29-2006 02:28 AM
