engine alignment - Triumph Forum: Triumph Rat Motorcycle Forums
New Bonneville
Old 09-07-2009, 01:28 AM   #1 (permalink)
Favourite Bike: monster cromo
Other Motorcycle: 1959 bmw r50
Extra Motorcycle: 72 tiger 650
engine alignment
Hi again, installing the rebuilt engine back into my 72 tiger 650 tr6r i have come across a couple of problems, first, trying to get the lower engine bolt and spacers in was really difficult, i even scraped of the new paint on the frame to get them in, then i noticed the front ones had a pretty good gap that closed up as i tightened the bolt, i then installed the rear brackets and tightened everything up but when i tried to install the upper engine brace the hole to the frame does not line up, its out about half a hole, is there a proper sequence for the install, i checked all my pre teardown pics and everything is in the same order, any ideas? thanks again
ecose is offline   Reply With Quote
Old 09-07-2009, 03:48 AM   #2 (permalink)
Favourite Bike: 1982 TR65 Thunderbird
epynt1050's Avatar
Other Motorcycle: 2011 Tiger 800
Extra Motorcycle: 08 Street Triple, 1913 "A
When you install the engine, leave all the bolts and brackets loose until everything is in place. Only then do you tighten up the bolts.
epynt1050 is online now   Reply With Quote
Old 09-07-2009, 12:03 PM   #3 (permalink)
Favourite Bike: '68' T120 Bonneville
Other Motorcycle: 2006 T100 Bonneville
Extra Motorcycle: '79' T140 street tracker
I don't know about the 72 but later OIF frames had different thickness spacers between the engine and frame from one side to the other. If they are swapped it would put your alignment off.
jimmy bush is offline   Reply With Quote
Old 09-07-2009, 01:22 PM   #4 (permalink)
Favourite Bike: Triumph Bonneville
Other Motorcycle: Triumph Speedtriple
The 72 also has different thickness on both the forward mount and the lower mount. I can't remember what goes where as my engine is on the bench but the easy way to check is to set the engine in the frame, install the lower bolt (without spacers) and then temporally install the rear mounting plates, you will need to slide the engine over a little bit to fit the plates and then all will become clear (it worked for me). I think the thicker spacers go on the right but cannot be 100% sure.
Webby
Webby is online now   Reply With Quote
Chain Alignment - wheel alignment Chalawah Maintenance & Workshop Talk 3 01-10-2008 05:06 PM
alignment? Orpheus Twins Technical Talk 5 09-18-2006 09:25 AM
alignment after rim removal Clarke5 Twins Technical Talk 7 07-19-2006 07:37 PM
Fork Alignment tealetm Maintenance & Workshop Talk 6 03-06-2006 07:46 AM
Fork alignment... tealetm Speed Triple Forum 2 02-26-2006 10:57 PM
