Tr6r Wet Sump Valve ? - Triumph Forum: Triumph Rat Motorcycle Forums
Old 09-06-2009, 11:08 PM   #1 (permalink)
Favourite Bike: monster cromo
Other Motorcycle: 1959 bmw r50
Extra Motorcycle: 72 tiger 650
i have seen these anti wet sumping valves mentioned in several places, i am building a tr6r 650 with a morgo 750 kit, its a 72 tiger oif, my question is do i need one? should i install one? thanks
ecose is offline   Reply With Quote
Old 09-07-2009, 07:58 AM   #2 (permalink)
Favourite Bike: T120R Bonneville (mine)
Other Motorcycle: I wish
Hi ecose,
If you are fitting a new pump you will be fine without one.
Wet sumping is caused through unseated balls in the pump, so fitting an extra valve will only mask the problem.
Plewsy is offline   Reply With Quote
oil pan / sump GunslingerRC Speed Triple Forum 14 04-21-2010 12:20 AM
1970 TR6R Leaking oil past intake valve breeze650 Classic, Vintage & Veteran 4 08-21-2009 09:45 PM
Need an oil sump pan. Titan1921 Speed Triple Forum 6 06-09-2009 06:37 PM
oil sump Agkistrodon Triumph SuperSports 1 06-25-2007 10:08 PM
Wet Sump HankQ Classic, Vintage & Veteran 4 06-22-2007 05:22 PM
