Tiger 650 Amal Carb 930?? - Triumph Forum: Triumph Rat Motorcycle Forums
Old 09-06-2009, 09:22 PM   #1 (permalink)
Favourite Bike: only one I got t100C 71
Flatrabbit's Avatar
Hey guys, Im building a OIF 72 Tiger 650, Should a Amal 930 Carb be ok? My real concern is I dont have a 930 slide. I got a 923 and some other ones. Does anyone know what the best carb set up is? its bored 40 over and everything else is stock... Thanks Alot! And thanks for plewskys Boyer Setup Video it kept me out of the mad house
Flatrabbit is offline   Reply With Quote
Old 09-07-2009, 08:44 AM   #2 (permalink)
Favourite Bike: T120R Bonneville (mine)
Other Motorcycle: I wish
Hi Flatrabbit
that 930 is fine,
as for the slide it should be a nice fit down the hole and have a 3.1/2 cutaway,
230main, 106 needlejet, Std needle, middle notch.
Glad the boyer vid kept you out the mad house ,
If it hadn't I might of seen ya!
ps my slides Have 928 stamped underneath,
I'm sure some one will clarify what this number means.
Plewsy is offline   Reply With Quote
Old 09-11-2009, 01:53 AM   #3 (permalink)
Favourite Bike: Mine
t100rc's Avatar
'928' is an Amal concentric model (28mm ... a 930 is 30mm, etc) ... all 900 series Amals use the same slides. The bore size difference is in the intake bore, not the slide bore. In other words, all 900 series concentrics use '928' slides ...
RC
'70 T100
'56 T110 (in progress)
Crossroads Cycle
t100rc is offline   Reply With Quote
Amal carb question... fightingzero Classic, Vintage & Veteran 14 11-22-2009 07:33 AM
Amal carb leaking 68tr6c Helmets 2 09-15-2009 12:50 AM
TR120R Amal Carb. HELP! FireTiger Classic, Vintage & Veteran 10 07-09-2009 07:50 PM
AMAL Carb : 689/205 Carb vs 376 series. 63Thunderbird Classic, Vintage & Veteran 3 07-08-2008 03:20 AM
Setting my Amal Carb quagmire Classic, Vintage & Veteran 3 04-10-2008 04:47 PM
