Amal 930 leaking through tickler - Triumph Forum: Triumph Rat Motorcycle Forums
Old 09-06-2009, 02:30 PM   #1 (permalink)
jrn
Hello I have a problem with my right side carb. I've taken it apart 3 times now and cleaned it. It's fine for about 5-6 miles then the gas starts pouring out the tickler like a sticky float. From my understanding with these plastic floats there is no adjustment on it so all you can do is clean it? Am I missing something here, the carbs are only 2 years old and I run fuel filters. Funny thing also, if I shut the petcock off and I still see plenty of fuel in filter, it will not run out of the tickler, only when the petcock is on and the revs get up does it start pouring out. Thanks
jrn is offline   Reply With Quote
Old 09-06-2009, 02:49 PM   #2 (permalink)
Favourite Bike: T120R Bonneville (mine)
Other Motorcycle: I wish
Hi jrn, and welcome to TR
take a look at these it will give you an Idea of what to do.
http://www.triumphrat.net/vintage-te...air-video.html
If your carbs do not have, Viton tip needles (rubber bit on the end) you should invest in a pair.
Plewsy is offline   Reply With Quote
Old 09-06-2009, 04:36 PM   #3 (permalink)
Favourite Bike: '67 Triumph Bonneville
Could also be a leaky float that isn't living up to it's name...
GrandPaulZ
Author of "Old Bikes"
Born Again Bikes
My Photo album
Old 09-06-2009, 09:48 PM   #4 (permalink)
jrn
It has a coated needle and the float is not leaking. I see now how to adjust the seat but I am not sure how to check the float. I pushed down on the needle and held it then pushed the plastic tabs onthe float to see how far it would raise. It appeared to be level with the top of the bowl is this where it's supposed to be? My book says nothing about the float level.
Thanks
Old 09-07-2009, 09:32 AM   #5 (permalink)
Hi jrn,
You should just lightly press down on the tangs, the gap at the front
( from bowl to float) should be 60-80 thou.
As quick fix, if they are not too far out, it is acceptable to fit two gaskets.
With the bowl removed and tickler released,
do the ends hang lower than the bowl face? (what is there position in carb)
Old 09-07-2009, 11:25 AM   #6 (permalink)
I need to scratch my brain, but how does 2 gaskets IMPROVE the situation?
GrandPaulZ
Born Again Bikes
My Photo album
Old 09-07-2009, 12:07 PM   #7 (permalink)
Favourite Bike: '68' T120 Bonneville
Other Motorcycle: 2006 T100 Bonneville
Extra Motorcycle: '79' T140 street tracker
By adding a gasket you increase the distance from the top of the fuel to the top of the float chamber. Same effect as lowering the float.
jimmy bush is offline   Reply With Quote
Old 09-07-2009, 12:13 PM   #8 (permalink)
Ah, yes, that's right, the seat is in the BOWL, not the BODY.
Ding!
GrandPaulZ
Born Again Bikes
My Photo album
Old 09-07-2009, 12:28 PM   #9 (permalink)
jrn
The vids are great, but the troubling part to me is my float seems to be set correctly. The needle looks to be in great shape as I said the carbs are only 2 years old and less than 2000 miles on them. It has to be a float issue because why else would the gas be coming out of the tickler? I'm thining about lowering the float a bit just because I'm stuck, but any other ideas would be appreciated. I might try the extra gasket to lower the bowl a tad and I'm assuming move the fuel level away from my tickler the thickness of the gasket. Obvioulsy my gas level has to be too high if it's pouring out of the tickler. Maybe it is time to dump the Amals which have been great up until now!
Old 09-07-2009, 04:53 PM   #10 (permalink)
Amals, especially new ones, are some of the easiest components to sort on a bike.
Never overlook the simple, stupid little things that can be done wrong to produce significant issues.
GrandPaulZ
Born Again Bikes
My Photo album
Extended tickler for Amal 930 Tiger Dale Classic, Vintage & Veteran 12 09-08-2011 01:36 PM
Amal concentric Tickler Kit SilverBullet Maintenance & Workshop Talk 1 06-29-2009 12:11 AM
Leaking gas from tickler gabsdad8 Classic, Vintage & Veteran 7 06-24-2009 09:00 AM
Leaking carburettor through amal conc tickler oilyframer Classic, Vintage & Veteran 14 07-05-2008 09:17 AM
amal leaking from tickler cat Classic, Vintage & Veteran 5 04-19-2004 07:37 AM
