Convert from single to dual carbs?? - Triumph Forum: Triumph Rat Motorcycle Forums
post #1 of 17 (permalink) Old 09-03-2009, 10:47 PM Thread Starter
Main Motorcycle: pre '68 Bonneville 750cc
Other Motorcycle: 86 Yamaha FJ1100
Extra Motorcycle: Custom mini-bike 165cc
I want to convert my 750 Tiger from a single to a dual carb. Before I rush out a buy anything I need some advice. From what I am told, this 73 TR7 750 Tiger is the same motor as a 73 T140 750 Bonneville. Does this mean the Bonneville intake manifold will bolt right on?? Are 30mm carbs the preferred? I assume I will also need a Bonneville throttle cable for dual carbs??
Thanks in advance
TangoMike
If it's not leaking oil, there ain't none in it.
tangomike is offline
post #2 of 17 (permalink) Old 09-03-2009, 10:57 PM
Main Motorcycle: T120RT
KADUTZ's Avatar
Other Motorcycle: T140V,T140D,T140E,T140J
If you bike is more or less stock you will need a 73 thru early 78 T140 head and bits head one 930 carb plus some internal pieces for your TR7 carb. T140 throttle cables and T140air box setup.
KADUTZ is online now
post #3 of 17 (permalink) Old 09-03-2009, 11:38 PM
tip rat's Avatar
and why do you want to do that?????????????????????????????albert the tiprat..
tip rat is offline
post #4 of 17 (permalink) Old 09-04-2009, 07:57 AM
Other Motorcycle: Triumph Speedtriple
You will also need a dual air control cable
Webby is offline
post #5 of 17 (permalink) Old 09-04-2009, 08:03 AM
Main Motorcycle: 1965 TR6SR
rmak's Avatar
Other Motorcycle: 2007 Scrambler
I just asked the question in reverse a while back. I got a 78 parallel port with Mkll carbs I'd love to trade for a Tiger set up. Pm me if you're interested, or if you're thinking of selling the head/carb/cable in favor of getting another. I also took off all the airbox stuff if that's needed.
rmak is offline
post #6 of 17 (permalink) Old 09-04-2009, 08:31 AM
Main Motorcycle: 72/3 tiger
Other Motorcycle: 04 america
WHY? WHY? WHY? It is nice when someone asks " is that an old bonnie" you can turn and say " no mate it's a tiger", they are stuffed they don't know. if you want it to go like a bonnie but keep the reliablity of a tiger just put a bigger carby on, mine has a 32mm on it (it was on there when i bought it), it goes hard, even surprises the harley blokes i ride with, one of which is a bike mechanic by trade that use to have a trumpy, he loves it
72TIGER-X is offline
post #7 of 17 (permalink) Old 09-04-2009, 10:12 AM
Main Motorcycle: '68 TR6R
68TR6R's Avatar
Other Motorcycle: 1978 suzuki 125
Dont put two carbs on! Keep it nice and simple like it is. Two carbs=twice the hassle. Way easier to tune the tiger.
68TR6R is offline
post #8 of 17 (permalink) Old 09-04-2009, 11:56 AM Thread Starter
I thought it may require a different head from the pictures I have looked at. It was just a thought. I figured since I may get a brand new carb anyway, why not upgrade a little. I am going to stay single carb on this motor for now, and just get a new one. Not because it's a Tiger and I want to keep it a Tiger, but because it is a lot easier. You see I have a different philosophy on my bike than some of you. I want what I want, personally. I'm not one to follow the crowd, so to speak. If it works for me and I like it, I don't care what others think, or say. Most of my bikin friends think I should own a Harley so I can ride with them. I have to laugh. I have reminded every one of them that while I like them a lot, I don't own a bike so I can ride with them, I own the bike I own because I like this particular one! One the same note, if I had a sweety unmodified purebred 73 Tiger and I liked it that way, I'd keep it that way. But if I wanted to put on Harley forks and a japanese carb I would do just that, due to personal preference. (I can feel people gasping for air right now) So, I bought this bike because I liked the potential it had to me personally. It was a beat up, run down 70's style chopper that had a Triumph frame(not Tiger), motor and forks. Everything else was pretty much Harley. I stripped it down, and built it back up, using as many Triumph parts as I wanted on it. I made it the way I wanted it to look, not the way somebody else wanted it to look. Since I am getting a new carb, I have decided to give a Keihin a try. I have used Amal, as you can see from some of my other posts, so I am getting familiar with them, but as my personal tastes go, I have had enough "experience" with them. I still need to figure out the differences in jetting between the two. I am looking at a Kleihin PWK 30mm as a replacement for an Amal 930 that has a 270 Main jet, 106 needle jet and a 3-1/2 slide?? Do you know any links explaining the jet size difference between an Amal and a Kleihin?
Thanks
TangoMike
post #9 of 17 (permalink) Old 09-04-2009, 12:01 PM
Main Motorcycle: 1970 Tiger 650 TR6
farric1's Avatar
Other Motorcycle: 1971 Norton Commando
Extra Motorcycle: 1979 Triumph T140E
Hi rmak
If you don't make the trade, and your head is in good shape, I'll buy it off you. Let me know.
Norton may have developed the oil leak, but it's Triumph who perfected it
farric1 is offline
post #10 of 17 (permalink) Old 09-04-2009, 12:05 PM
farric1's Avatar
Thanks in advance
TangoMike
Hi TangoMike
There is very little to nothing to be gained by going dual carb on a T140 Tiger. Definitely not worth the bother. Some may even argue that the Tiger pulls better lower down. It's up to you, but the hassles will definitely outweigh any slim advantage you might get.
farric1 is offline
Single to Dual Exhaust for 01 955i? bradastan Speed Triple Forum 8 05-12-2009 10:59 PM
Single vs. Dual Cans? dgrtech Street Triple Forum 2 06-09-2008 06:13 PM
Anyone convert to single headlight? Redbeard77 Speed Triple Forum 27 05-11-2007 02:45 AM
dual front brake lines vs. single BulldogHooligan Speed Triple Forum 8 04-05-2007 06:29 PM
CONVERT DUAL HEADLAMPS TO SINGLE? vladislav Speed Triple Forum 2 07-03-2005 04:27 AM
