Another Rear Master Cylinder Question - Triumph Forum: Triumph Rat Motorcycle Forums
Motorcycle.com Classifieds!SportbikeTrackGearOntario TourismHonda Powersports
Old 08-08-2009, 05:39 PM   #1 (permalink)
Favourite Bike: 03 TBird
Beemie's Avatar
Other Motorcycle: OIF Bonnie
In rebuilding or fitting a new rear T140 master cylinder, all three shop manuals that I have say to check and adjust the distance between the master cylinder body and the actuating rod nut to be .35"-.37", so roughly 3/8".
None of the books are specific as to whether they mean with the rod extended, thus giving only a stroke of 3/8", or with the rod compressed to its in position, leaving 3/8" space when the brake is applied.
It would seem that they may mean when the rod is out giving a 3/8" stroke before the nut stops the travel without pushing the rod to strike whatever is inside. But then again, that's not much stroke.
Anyone been there and done this?
Book Authors!!!
Beemie is offline   Reply With Quote
Old 08-08-2009, 05:55 PM   #2 (permalink)
I've just recently replaced my rear MC. As I understood the Lockheed instructions, that adjustment is made independent of the MC itself, as the adjustment is between the back face of the nut and the end of the bracket. I set mine before screwing the MC into the bracket. Or, if done with the MC installed in the bracket, if the MC was adjusted properly to make sure the bleed hole isn't covered, the play will have just barely been taken out of the rod. So, yup, only a ~.360 stroke. My new stainless MC is one of the 13mm bore variety, so that makes for VERY little volume of fluid being moved. Which (among other things) contributes to making bleeding it a fairly significant PITA. But, now that mine has all the air out, the rear brake works really well! I can skid the rear tire at will. Combined with new EBC pads front and rear, I think it probably stops better now than it did when new.
- Dave
1977 T140V Silver Jubilee
1970 T120RT
Dave Affleck is offline   Reply With Quote
1979 T140 Rear Master Cylinder BonnevilleJoe Classic, Vintage & Veteran 17 02-10-2010 02:57 AM
T140 Rear Master Cylinder Beemie Classic, Vintage & Veteran 7 07-24-2009 10:10 PM
PLease help! Cant remove rear master cylinder on 76 bonniville. blackienig Classic, Vintage & Veteran 6 10-15-2008 06:47 AM
Remote Reservoir for rear Master Cylinder MORRISTHECAT Classic, Vintage & Veteran 1 02-14-2008 12:58 AM
Rear master cylinder bolt goes airborne Lanont Twins Technical Talk 3 05-20-2007 06:56 PM
