1970 Bonneville rear hub bearings - Triumph Forum: Triumph Rat Motorcycle Forums
SportbikeTrackGear
Motorcycle.com Classifieds!New BonnevilleOntario Tourism
Old 08-07-2009, 11:09 PM   #1 (permalink)
I want to replace the bearings in my rear hub. I have the factory parts manual and workshop manual but I am stuck. On the speedo side the is a retainer that is threaded. I need to now if it is right or left thread and the best way to loosen it . Here are pics of what I am looking at
Another view
The axle assembly
Thanks
NeoDutch59 is offline   Reply With Quote
Old 08-08-2009, 06:01 AM   #2 (permalink)
Favourite Bike: '72 Bonneville
RetroRod's Avatar
Other Motorcycle: Suzuki GSX1400
I'm almost certain it's a RH thread, as this retainer drives the speedo gearbox, and would undo if LH thread. In almost all cases where it can be stamped, LH threads are so marked. RR
RetroRod is offline   Reply With Quote
Old 08-10-2009, 07:58 AM   #3 (permalink)
Favourite Bike: T140 E
pretty sure that it is - my T140E's was.
If it's difficult use a hot air gun to expand the metal. Mine needed about 20 mins of heat using a 2Kw gun moved all around the area.
DAVE M is online now   Reply With Quote
1970 T120R Bonneville Help LGSpiker Classic, Vintage & Veteran 7 02-07-2010 04:26 PM
D1200 steering head bearings and rear suspension bushes and bearings triday12 T3 Sport / Touring Forum 3 07-13-2009 07:11 PM
Help with value of 1970 Bonneville DWIT100 Classic, Vintage & Veteran 5 09-05-2008 08:31 PM
1970 Bonneville BTHUMPER Twins Talk 4 09-11-2005 05:38 PM
1970 Bonneville T120R Classic, Vintage & Veteran 21 11-27-2004 11:22 PM
