Originally Posted by delrazor
Rod, The guides were letting in oil to the chambers about 4ml /mile.....................
derek
Derek,
I'm curious about how you know that the guides were
"letting in oil to the chambers about 4ml /mile" Oil injected into the motor this way is usually sucked down the valve guides by high vacuum in the chamber under decelleration.
It is seen often enough in vehicles that have slowed for the stop lights, idled awhile, and then let go this huge cloud of blue smoke at take off that quickly subsides under accelleration. Oil usage from this would be high around town and virtually nil on the highway (did you notice, or have you been told about similar symptoms on this engine?).
So, with oil consumption running at 6.66 pints/1000miles (very excessive: and I wonder if this much oil could make its way down the valve guide), you just need to be
certain its coming from the head, or your limited resources will not be well spent.
The Triumph motor does not have lots of oil around the valve guides as it returns quickly to the sump via oil valley in the head and the push rod tubes (PRT). On a budget, it would be cheaper to fit a cap type valve stem seal than to go the full nine yards with a reconditioning of the head.
The above comments assume the guides are tight in the head and have not loosened, which if the case, excessive oil would enter the chamber this way
The crack may well be left alone. Remember if it is repaired properly, the preparation and welding will require that the head be refaced and that could bring your way another can of worms. Not having seen the head, one cannot say one way or the other, but looking at the thing as a whole: you've had v.good compression on this engine so clearly the crack is not a problem now, and may never be.
It is never easy to make decisions when, on one hand, a full and good repair of everything is horribly expensive, and on the other, the conflict of limited resources. Engines generally do not respond well to being half done up. In your case it may be a case of spending as little as possible (ie, rebuild with existing parts), or go for broke and do everything from the ground up with new gear ( ie, reconditioned top end and repairs to whatever you find in the crankcase). Not always an easy call Derek. RR
