68 bonnie headlight? - Triumph Forum: Triumph Rat Motorcycle Forums
Old 08-06-2009, 06:52 PM   #1 (permalink)
Newbie
My light bulb burned out. Im wondering if there is a better solution to achieving a brighter light, new bulb or possibly some modification other than stock any info will help thx.
zbundy is offline   Reply With Quote
Old 08-06-2009, 10:56 PM   #2 (permalink)
Favourite Bike: 1979 Bonneville
Zbundy,
Ok, which bike would help? 6 volt or 12 volt? Type of charging
system?
The only way to get a brighter light is running more wattage,
some bikes can not handle that. A sealed beam will remain
brighter longer as the reflector does not get dull with time so
that is a possible up grade as well.
Pookybear
pookybear is offline   Reply With Quote
Old 08-06-2009, 11:23 PM   #3 (permalink)
Favourite Bike: 1959 Triumph TR6
Other Motorcycle: 2003 HD Road King Police
I have had several Brit-bikes from the 60's ,all 12 volt. I ran a standard 7inch sealed beam. The local auto stores should stock them. But, you may run into a problem with the standard socket. If I remember right, I used one, and had to bend a few tabs on the toggle switch, stuffin all that stuff into the headlamp shell. The bike I have now, I rewired everything and soldered the wires to the sealed beam. To me, it's no big deal to desolder to replace, which I just did a few weeks ago.
Red1959 is offline   Reply With Quote
Old 08-07-2009, 12:23 AM   #4 (permalink)
Favourite Bike: T120RT
Other Motorcycle: T140V,T140D,T140E,T140J
you can use a 6014 std or 6024 sealed beam halegon bulb these will go into your headlight ring with no problem. however these bulbs are an automotive bulb and probably not survive for a long period of time due to vibration but they are relatively low cost. a better choice would be a 6015 bulb which is a heavier duty bulb that was used in trucks. The best choice is would be to go to a Jap Bike dealer and get a motorcycle sealed beam. the example I have used for years is the bulb from a Yamaha XS650 from say 77 thru 81. all these bulbs are 12volt and have a standard 3 prong connection. Any auto parts will be able to sell a replacement 3 wire pigtail to plug on the lamp. put a bullet connector on each wire and you can plug into your factory loom. course you have to take out the factory bulb holder.
KADUTZ is offline   Reply With Quote
QUICK Bonnie Headlight Question? SkyoodPOV Club Cafe' 10 01-18-2008 07:44 AM
What size headlight does the Bonnie have? xardoz Twins Technical Talk 3 02-15-2007 09:50 AM
Scrambler vs. Bonnie headlight JonahP Twins Talk 3 11-20-2006 08:57 PM
Bonnie headlight crack trumpyfan60 Twins Talk 2 03-17-2006 06:54 PM
