Fuel filters - Triumph Forum: Triumph Rat Motorcycle Forums
Old 08-04-2009, 05:28 PM   #1 (permalink)
Favourite Bike: 1970 TR6 Spring Gold!
Fuel filters
Other than the plastic filter in the banjo fitting on the carb and the filter in the petcocks, anyone also put and in-line fuel filter on their bikes?
Hey, What's this oil on the floor?
quagmire is offline   Reply With Quote
Old 08-04-2009, 05:45 PM   #2 (permalink)
Favourite Bike: 2002 Triumph Trophy
Other Motorcycle: 1970 Triumph Tiger 650
Extra Motorcycle: 1999 Yamaha Virago 1100
Hi Quag,
I've used the in-line ones when I had my BMW; they were the ones you get at an auto store or even a hardware store.........plastic push-ons. The clear ones look the best. I've never used them on the Triumph as I believe that the old Amal carb is simple enough that it just passes minor "bits" right through it. Oddly enough, the fuel lines hang just a bit below the banjo of the carb and I've found some "grunge" settled there. Obviously, a big plus for clear fuel lines.
Filters on a British Bike?? HERESY!!! Jim
Jim Ballard
jimballard is offline   Reply With Quote
Old 08-04-2009, 05:46 PM   #3 (permalink)
Favourite Bike: '68' T120 Bonneville
Other Motorcycle: 2006 T100 Bonneville
Extra Motorcycle: '79' T140 street tracker
I'm running some in line filters. Don't know the brand but you can pick up some at most any bike shop for a few bucks each. They usually have several different types to choose from. I don't know if they do any good other than peace of mind but I haven't had any overflowing due to trash under the float needle or stopped up jets since I installed them.
jimmy bush is offline   Reply With Quote
Old 08-04-2009, 07:00 PM   #4 (permalink)
Favourite Bike: 1974 T120V
Other Motorcycle: 1972 T120R
I have a glass one with removable filter. I have both petcocks into a T-piece to the filter, and then from the filter to another T-piece to both carbs. The filter is quite long and would suit being half the length to fit in the space better, but it gives a good flowrate.
Mark
mark61120 is offline   Reply With Quote
Old 08-05-2009, 05:21 AM   #5 (permalink)
Favourite Bike: '72 Bonneville
RetroRod's Avatar
Other Motorcycle: Suzuki GSX1400
OK, I'll be the dill to ask the obvious question, why would you bother? RR
RetroRod is online now   Reply With Quote
Old 08-05-2009, 09:18 AM   #6 (permalink)
Retrorod, I was wondering when someone would ask. I'm having a problem with my bike running. I don't ride very much, maybe a few times a month. A few weeks ago it ran perfect. Started with one kick, idled great and pulled nicely. This past weekend I took it to the bank. Or tried to. The bike will start, but only with the choke on. If I turn the choke off it dies, even if I hold the throttle open. When I start riding and turn the choke off I get no power and the bike backfires. It runs very nicely with the choke on. Yes I know the choke is on when the lever is slack.
The idiot in PA who painted my tank (see past threads) put that POR-15 crap in my tank. Since the day I got it back that stuff has been peeling off. I'm wondering if some of that stuff is clogging up my carbs. So now I have to try and remove that crap without damaging my paint job.
Or could it be the gas. I always use the highest octane , usually 93 or 94. Could it be by sitting for a couple of weeks the gas cloggs the jets?
I have a brand new Amal carb and it boggles my mind why one time the bike runs great and the next it doesn't.
fuel filters kubbie Triumph SuperSports 10 07-31-2008 07:03 AM
Fuel filters tomsdad Hinckley Classic Triples 3 05-31-2008 04:51 PM
Fuel Filters Doublenikkel Sprint Forum 4 05-06-2007 09:30 PM
on fuel filters Geoff Twins Technical Talk 5 03-13-2007 10:57 AM
Fuel Tank paint clogging fuel filters on Adventurer Hinckley Classic Triples 3 03-09-2005 04:41 PM
