Where can I buy an oil leak? - Triumph Forum: Triumph Rat Motorcycle Forums
Motorcycle.comNew BonnevilleSportbikeTrackGear
Old 08-03-2009, 04:11 PM   #1 (permalink)
Now you might think this a bit strange. All my old Triumphs vented oil from the engine breather onto the rear chain, so kept them oiled and in good condition. In response to all those that called these oil leaks, my new Enfield does not leak. Is completely dry. So was the chain, and it has worn out in 8k miles. I fitted a new one today of hopefully better quality but I also need to buy an oil leak to help increase chain life. I beleive they are sold under the name of 'scottoiler'. Just seems wrong to have to spend money to create a leak. I guess fashions go in circles. I have no doubt that in 40 years time they will have great advances in motor technology and invent engine breathers that lubricate chains. Probably be a thriving after market for 'small bore kits' to make engines run smoother and more economically. Who knows they may even invent rear wheel stands so you can remove/replace the rear wheel without lying a bike on its side.
A wise man learns from his mistakes..
A genius learns from other peoples mistakes.
panda is offline   Reply With Quote
Old 08-03-2009, 05:35 PM   #2 (permalink)
Favourite Bike: 2002 Triumph Trophy
Other Motorcycle: 1970 Triumph Tiger 650
Extra Motorcycle: 1999 Yamaha Virago 1100
..and, better yet, an ignition system that creates it's own spark without the need for a battery (we could call it a magneto) and a lever on the side of the gearbox/primary chaincase that would be foot operated, thereby dispensing with the embarrassment of calling for assistance should one's battery go kaput!!
The "village idiot's" mind is a cesspool of ingenuity and engineering: Jim
Jim Ballard
jimballard is offline   Reply With Quote
Old 08-03-2009, 06:38 PM   #3 (permalink)
Favourite Bike: 1976 Triumph T-140V
thirdbike's Avatar
Other Motorcycle: 1950 Matchless G80
Extra Motorcycle: Yamaha 1200
I must be missing something here. Are you saying you prefer to use engine oil to lubricate your chain as opposed to chain lube?
thirdbike is offline   Reply With Quote
Old 08-03-2009, 06:53 PM   #4 (permalink)
Favourite Bike: 1982 TR65 Thunderbird
epynt1050's Avatar
Other Motorcycle: 2011 Tiger 800
Extra Motorcycle: 08 Street Triple, 1913 "A
Try http://www.mandp.co.uk/productsList....er3=Scottoiler
epynt1050 is online now   Reply With Quote
Old 08-04-2009, 06:26 PM   #5 (permalink)
I remember them well
My Enfield does have a kickstart, but needs at least 7 volts for the 'black box' to work. The old 'emg' on the ignition switch on my old Triumphs did give you a sense of independance and confidence should you forget to turn something off. Hint, dont try to kickstart on a dead battery with the headlights switched on
Old 08-04-2009, 06:37 PM   #6 (permalink)
Originally Posted by epynt1050 View Post
Thanks for trying to be helpful, but you missed my point.
Because Enfield have succumbed to the cries of 'oil leak' they no longer vent oil onto the chain. To get that function back ie an oil leak, will cost more than the price of a new nicasil alloy barrel and piston or a crankshaft and conrod assembly. It just does not seem right that it should cost that much to buy an oil leak.
I would rather they reverted to a timed breather onto the chain.
Thirdbike, engine oil is a good lubricant for chains. It just has to be applied so the chain does not run dry. Engine breathers tend to satisfy this need, particularly with dry sump engines. Most cam and primary chains are lubricated with engine oil, and they last much longer than those exposed chains that get squirted from time to time with chain lube. Besides, chain lube is really there to lubricate the soft sealing rings, rather than the actual metal wearing components of an old style chain with a split link.
Old 08-04-2009, 06:49 PM   #7 (permalink)
Thirdbike, engine oil is a good lubricant for chains. It just has to be applied so the chain does not run dry. Most cam and primary chains are lubricated with engine oil, and they last much longer than those exposed chains that get squirted from time to time with chain lube. Besides, most modern chain lubes are really there to lubricate the soft sealing rings, rather than the actual metal wearing components of an old style chain with a split link.
Leak Baby Leak, More! More! timbo2 Twins Technical Talk 25 06-17-2009 11:05 PM
another oil leak sweatmachine Twins Talk 10 05-23-2006 09:33 AM
oil leak BornAgain Twins Talk 3 04-23-2006 06:31 PM
Oh Joy an oil leak grumpyoledude Twins Talk 13 11-06-2005 12:03 PM
05 S3 OIL LEAK! Hairball Speed Triple Forum 4 05-20-2005 10:30 PM
