Stop light gremlins
I've been gradually cleaning and making operational all of the switches and lights on my new T140E. The last real big hurtle is the brake lights. They worked lousy when I got the bike, coming on whenever they wanted to.
When I test with an ohm meter I get a reading through the foot pedal from the white to the two browns and can break the circuit when I push on the pedal. I also have power through a test light from white or brown to a ground unless I push the pedal, then I just get a light through the white to ground.
On the grip switch, I do not have a reading with an ohm meter through the switch, but have power to ground from both white and brown?? This power to ground check works for both sides regardless if the switch is off or engaged unless I push the brake pedal then the brown goes dead.
I can make an ohm check connection from the grip brown to the pedal brown. However, I cannot make any connection in any way to the wire at the end for the tail/stop light from either switch . No wire to ground light regardless if I push the pedal, squeeze the grip or not. Nothing at the tailight end.
If you are confused, sorry, but that's how I feel. I know the brake light is screwy because you have to break the connection in the switches to make a circuit for the light. Or so I do believe.
The white I believe to be fine since that's the power and everything has power except the tail light. The brown looks good visually everywhere except where I can't see because of black tape.
Bad switch? Broken wire? Electrical dummy? One, two or all? Help and thanks.
