5 Speed Front Sprocket Spanner? - Triumph Forum: Triumph Rat Motorcycle Forums
Old 08-01-2009, 10:10 PM   #1 (permalink)
Favourite Bike: 03 TBird
Beemie's Avatar
Other Motorcycle: OIF Bonnie
Does a standard socket fit on the front sprocket nut on a 5 speed T140? If so, what size?
The manual calls for a Triumph issue spanner that is pretty expensive, let alone quite difficult to find.
Beemie is offline   Reply With Quote
Old 08-01-2009, 10:52 PM   #2 (permalink)
Favourite Bike: 1976 Triumph T-140V
thirdbike's Avatar
Other Motorcycle: 1950 Matchless G80
Extra Motorcycle: Yamaha 1200
Good Question
I couldn't find a socket that large that was also deep enough to clear the shaft. Necessity being the mother of invention, I made mine. I cut the hex nut pattern out of a piece of 3/16" plate which I welded to a piece of pipe. Another piece of plate at the other end of the pipe to engage my1/2" socket and a bit of care and filing to ensure a snug fit and some paint. I was concerned that too much torque would be required and gnarl the plate material but it worked like a charm.
Hope this helps.
thirdbike is offline   Reply With Quote
Old 08-01-2009, 11:45 PM   #3 (permalink)
Beemie's Avatar
thirdbike, what is the nut dimension?
Old 08-02-2009, 12:03 AM   #4 (permalink)
thirdbike's Avatar
Nut Dimension
Hey Beemie,
Not sure how you guys measure in your neck of the woods but I get 7/8" across the flats. I had tried a 3/4" drive socket but even they aren't deep enough. Deep sockets in those sizes are special order and costly
Old 08-02-2009, 12:28 AM   #5 (permalink)
Beemie's Avatar
Originally Posted by thirdbike View Post
Hey Beemie,
Measurement would be flat to flat across the middle and 7/8" isn't really that big, so I may not be understanding you. Did you mean that one flat measures 7/8" long? How many sides on the nut?
The Triumph tool may run about $45 or so plus shipping, so that should buy one heck of a socket.
Old 08-02-2009, 12:56 AM   #6 (permalink)
thirdbike's Avatar
sorry TYPO that should read 1 7/8" and its a standard configured hex nut
Old 08-02-2009, 01:37 AM   #7 (permalink)
Beemie's Avatar
Thanks,
How much would you estimate the shaft to protrude from the face of the nut?
Old 08-02-2009, 04:22 AM   #8 (permalink)
Favourite Bike: T140 Bonneville
gumpt1oo's Avatar
Other Motorcycle: T100 Bonneville
Hi Beemie, here's a couple of pics of mine.
We're all doomed!
gumpt1oo is offline   Reply With Quote
Old 08-02-2009, 10:55 AM   #9 (permalink)
Beemie's Avatar
It's surprising that the oem spanner only takes a rod through the body to work it.
The newer Thunderbird requires quite a torque on that nut.
Old 08-02-2009, 12:59 PM   #10 (permalink)
Favourite Bike: 1978 Triumph Tiger 750
hobbit's Avatar
Other Motorcycle: XLH883C Sportster
I believe it's 1.66" whitworth, approx 43mm
Amazing things indicators . . . pity yours don't work.
http://www.aavmcc.com
http://www.shinbukankendo.com
hobbit is offline   Reply With Quote
Front sprocket on 5 speed 1995 T-Bird enew Hinckley Classic Triples 15 06-16-2009 09:45 AM
Speed Four front sprocket SDFOUR Triumph SuperSports 5 05-28-2007 05:20 PM
Front sprocket RandyDTFR Twins Technical Talk 20 11-03-2006 04:35 PM
Have I got a bad 18T front sprocket? kdlutes Twins Talk 20 07-19-2005 06:29 PM
front sprocket tri99sprint Tiger Chat 9 05-11-2005 01:33 PM
