T140 front sprocket problem. - Triumph Forum: Triumph Rat Motorcycle Forums
Old 07-31-2009, 05:10 PM   #1 (permalink)
Favourite Bike: T140 Bonneville
gumpt1oo's Avatar
Other Motorcycle: T100 Bonneville
Hi Guys, I have recently bought a 1979 T140. It needed new chain and sprockets, so after watching Plewsy's excellent clutch removal video, I set about changing the sprockets. I successfully removed the clutch and the circular cover to access the front sprocket.
Got the big nut off the shaft and the sprocket will not fit through the hole in the casing!
The new sprocket Is a 20 tooth the same as the original and it just fits through the cover.
The diameter of the old sprocket is about 1mm to big. Anyone come across this problem before?
The only way around as I can see is to run a dremel around the casing until the sprocket comes through.
All advice welcome!
We're all doomed!
gumpt1oo is offline   Reply With Quote
Old 07-31-2009, 07:03 PM   #2 (permalink)
Favourite Bike: '74 850 Commando
daveforty's Avatar
Other Motorcycle: '79 T140E
Extra Motorcycle: '06 Scrambler
If the old sprocket is that much oversize, then I guess whoever assembled the thing must have done it by taking the gearbox out and removing the mainshaft sleeve (5th) gear and re-assembling the gearbox with the sprocket in place. You may have to do the same to get it apart. Not complicated work, just long winded. I wouldn't suggest taking a Dremel to the cases. Someone got the oversize sprocket in there - you can get it out.....
daveforty is offline   Reply With Quote
Old 07-31-2009, 07:28 PM   #3 (permalink)
Favourite Bike: pre '68 Bonneville 750cc
Other Motorcycle: 86 Yamaha FJ1100
Extra Motorcycle: Custom mini-bike 165cc
If you are going to use a dremel tool, use a cutoff wheel on the front sprocket and leave the case alone. What's that you say?? Sounds like a lot of work?? I'm sure it is. I used a dremel to cut a hunk of chain out that was seriously wedged between the case and the sprocket.
TangoMike
If it's not leaking oil, there ain't none in it.
tangomike is offline   Reply With Quote
Old 07-31-2009, 08:31 PM   #4 (permalink)
Favourite Bike: 1979 Bonneville
All advice welcome!
Gumpt100,
Yes you are most right the new sprockets at the 20 tooth size just
squeeze through. So a dismantal of the transmission to remove
a larger sprocket is the proper way. Now back to the way everyone
else does things. Twenty small notches can be cut to get the
larger sprocket out. Make sure the notches have no sharp edges
and everything is nicely rounded. Or....
You can take that dremel of your and cut down the old sprockets
teeth and save your cases. As I would think you are replacing the
sprocket to put it into the trash so who cares if you grind on the
sprocket.
Pookybear
pookybear is offline   Reply With Quote
Old 08-02-2009, 04:29 AM   #5 (permalink)
gumpt1oo's Avatar
Thanks guys, mission accomplished! On closer inspection, and after cleaning all the crap off, there were 20 small marks around the casing, it was just a matter of turning the sprocket around until the right position was lined up and it squeezed through the hole!
We're all doomed!
Old 08-02-2009, 07:06 PM   #6 (permalink)
Well,
Easy Breezy, when someone else does the work for you. That is
great.
pookybear
Older front wheel on a 1973 T140? LukeSmith1985 Classic, Vintage & Veteran 9 07-28-2009 07:59 PM
T140 Kick Start Problem spartan Twins Technical Talk 0 07-26-2009 09:50 AM
Sprocket - Is this a problem thistle66 Twins Technical Talk 9 07-25-2009 03:53 AM
front sprocket nut starfighter Sprint Forum 2 03-09-2009 04:58 PM
T140 replacement front brake lever/cylinder yellowtrumpet Club Cafe' 6 11-07-2006 01:19 PM
