Originally Posted by 1973 724
just got my first bike. i have a 1973 (jan) t140v. 15000 miles matching numbers mostly origional. thinking of upgrading carbs (any suggestions appreiciated) i can use direction. its in good shape but springing leaks everywhere... seems comon though. and lots of clatter in the top end ... it seems to quiet down after a while but noisy till its fully warmed up. fun ride, i'll keep this sucker forever, i just want to catch up on the previous owners neglect
Welcome to the forum. As for carburators, eh... the original Amals
are nice. Mikunis, can be made to work with some work, do not
go above a 30mm. I have seen vintage Posas before, most of the
time as displays, very have to get right. But for easy, go with
the Amals.
As for leaks, get them fixed, untill then check your oil daily, do not
want to run it dry. Check you valve lash when cold, there is a nice
video done by Plewsy on this subject cover the subject. And if you
have not already change all of your fluids with fresh oils.
Pookybear
