Originally Posted by oldroadie
I have an opportunity to acquire this 1969 Tiger at what I think is a fair enough price (considering I've been lusting for a bike to restore). So far only pictures have changed hands but I can obtain it this Saturday, August 1st. Will you knowledgeable folk give me some guidance on things to look out for when I finally see it in the flesh?
oldroadie,
These are a fine bike. The single carb makes for good reliability, smoothness and economy with little sacrifice in performance compared to the twin carb Bonnie. You will be pleased by the handling and flickability of the bike. Even the drum brakes are rather good for the vintage (No worse than the later single disc fitted to the T140's) In addition, it looks like your machine has a Mikuni carb fitted (I could be wrong) which is a plus. No tickling required or prematurely worn slides! With the Mikuni, you should see about 50-55 mpg (English gallons) on a steady cruise.
There seems to be no instruments fitted. If the owner does not have them, get a quote for replacement items and use this to bargain with.
The machine looks like it's been restored fairly recently. Check that the bike has matching numbers. How good are the wheels? Rechroming and rebuilding can be expensive, so factor this in, if necessary.
Start the bike, check for oilsmoke. If so, check with the owner as to how recently the topend has had a service. Also, how far has the bike travelled on the current barrels and pistons? Factor this in as well.
Everything else is much the same as you expect to check for in any secondhand bike.
You may find, if you ride the bike, that it revs a little hard at 60mph. This is beacuse Triumph fitted a 19t Gearbox sprocket. Fitting a 20T sprocket makes for more relaxed cruising at Freeway speeds.
You need some decals to finish off the side panels. Very cheap and easy to obtain. Satisfying to apply!
I'd buy this bike if it were available to me if the price and condition matched and I lived in the US!
Good luck, I look forward to hearing more about this bike.
Regards
farric1
