Hi Cravatekid
If the tak taps are like mine ('79 Bonnie), then:
The one on the right is the main tank tap and you need to have the lever vertical for on and horizontal for off. The tap on the left is the Reserve tap and this should be horizontal for off and vertical for on. If you're not running on reserve, IE, if you have plenty of fuel, then leave the left tap in the off position.
With regards to fuel, you should NOT run your bike on unleaded because your valve seats are designed for leaded fuel. The lead in the fuel lubricates the valve seats and stops them from damage. If you use unleaded, the valve seats will suffer and wear prematurely. I get Lead Replacement Fuel from Tescos petrol stations. I imagine all of them have it?
Pete
