| Classic, Vintage & Veteran For Coventry and Meriden Models. Anything pre-Hinckley goes. |
07-05-2009, 10:29 AM
Formula Extreme Favourite Bike: 1968 Triumph Bonneville
Posts: 769 Other Motorcycle: 2008 Harley Fat Bob
2 Amal carbs-One with and one without Pilot Jet
The Amal 930 carbs I have on my 68 Bonnie look like the originals. Inside, both had almost same wear and looked identical in terms of dirt and discoloration etc.
However, one had a pilot jet and the other did not. Would this be possible to happen on a brand new bike back in 68? Or has the owner changed one carb over the years (I can't think how this could happen)?
I understand these carbs may or may not have pilot jets -- was there a particular year the made the switch?
Cheers.
07-05-2009, 10:43 AM
SuperSport Favourite Bike: T120R Bonneville (mine)
Posts: 1,381 Other Motorcycle: I wish
Hi Kev_England,
If you look at the carb body behind the tickler, where it says 930 look for a faint stamping just underneath, its the year of manufacture.
The one with the jet could be a later carb or a mod, if it is a mod the original pilot bush needs to be drilled out.
07-05-2009, 10:58 AM
Plewsey:
Yep, the markings are sort of different so Im thinking these carbs are from different batches. I can't see 100% but it looks like:
Pilot Jet Carb: 930/21 with an 'R' stamped sideways.
No Pilot Jet Carb: 930/10(?) with '39' stamped sideways (Note: the 39 could be R9 or B5 or something similar - its very faint)
No year stamped. Are these codes? Maybe special codes to confuse the Germans?
Surely no one would 'mod' a carb???!!!!
07-05-2009, 02:26 PM
The markings are very faint, R for right, L on the left one, the numbers are two digits like 66 or 70 pertaining to year and usually just below 930.
I wonder if your b5 is 65
As a mod that one is perfectly acceptable  in fact if you look closely at the hole with out the jet, I bet its threaded.
Reason: add image
07-05-2009, 03:37 PM
SuperBike Favourite Bike: 1982 TR65 Thunderbird
Posts: 1,672 Other Motorcycle: 2011 Tiger 800 Extra Motorcycle: 08 Street Triple, 1913 "A
930 is the carb series and size. 900 series are concentric Mk1. The 30 refers to the body being 30mm. The /21 and /10 are spec to which the were produced. ie cut out, needle position etc. /10 is the Bonnie spec for a left hand carb for 1968/69. Prior to that (ie for 1967) the carbs were Monobloc to DU59319, concentric thereafter (US market only).
930/21 is a BSA spec right hand carb on a 68/69 A65 Lightning or Firebird.
The two carbs started out in different bikes.
07-05-2009, 04:16 PM
Site Supporter Moto Grand Prix Favourite Bike: Triumph Bonneville
Posts: 2,765 Other Motorcycle: Triumph Speedtriple
Hi Plewsy,
I don't want to disagree with you, but I liked your photo so much I went to have a look at my carbs, my R/H is marked 66 just like in your photo and my L/H is marked 67. Thinking this was a bit odd to have 66 & 67 carbs fitted on a 72 bike (I was thinking maybe the casting date) I checked the specs in the workshop manual and the carb types are stated as being Type R930/66 and L930/67 with R930/60 & R930/65 fitted to the single carb models.
Webby
PS: I wasn't looking trying to prove you wrong, after reading your post I thought "cool, I'll go & see if I've got the original carbs on my bike"
07-05-2009, 04:47 PM
07-05-2009, 04:52 PM
The mystery deepens?
If I saw 72 stamped on my carbs I would assume the it's build year as well
Time for a bit more research I think!
Someone out there will know!
Webby
07-05-2009, 04:56 PM
the stamping 72 and 73 are the build spec, not the yr.
07-05-2009, 04:57 PM
Well lads,
I wish my carbs had the year on them like yours. But, mine do indeed have these strange markings:
I think epynt is on to something. epynt -- could you tell us the source of this information? And thanks very much!!!
